Results 1 to 12 of 12
Thread: Slight clunk from drive train..
    VS Calais
    Oct 2009
    Default Slight clunk from drive train..
    Heyas,
    Lately my VS has been letting off a slight clunk from, I believe, the diff.. im not very savy with cars so im not 100% how serious the problem is..
    It will clunk on gear changes, when I take my foot off the gas and it also clunks giving it gas.. say I give it a bit of gas, it will clunk and then it will accelerate.. it doesnt always do this, but it does it more times than not!
    It will also do this if im stationary changing gears manually (it' an auto)!
    I haven't checked anything, I wouldnt know where to start..
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I'll say rear upper trailing arm rear bushes are shagged.
    Edit: chances are you git IRS so i might be wrong but still worth checkin out
    Reaper
    vs clubsport
    Aug 2008
    im having the same issue with my vs 5.0l but its manuel
    i get the clunk sound between gear changeds and mainly on n off the gas pedal and also slowing down in 2nd gear and taking off and stop n go
    my diffs been rebuilt also tail shaft bearings been replaced new engine mounts have been down i dont know wat it is but soo pisses me off just makes me dont drive it thats how anoying it is
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by mr_clubby96 View Post
    as above check your upper arms, especially if its live axle. Its much better to drive if they arent fugged.
    Reaper
    vs clubsport
    Aug 2008
    hey mate i noticed when after i went for a drive in the clubby got outta the car and heard a squeek sound from the rear while i was jumping outta the car
    vs clubsport
    Aug 2008
    i think u have solved my problem VrWagZ1
    il post up some pics of how they look 2 me they look like they have shrunk only lil abit rubber left on them il put some picks after i eat hehe
    Attached Thumbnails Attached Thumbnails Slight clunk from drive train..-dsc00625.jpg   Slight clunk from drive train..-dsc00628.jpg   Slight clunk from drive train..-dsc00627.jpg
    VrWagz1's Avatar
    May 2008
    wollongong
    they dont look to be sitting right, have a play with your screw driver with it and see if it looks flogged inside where the bolt goes through. Upper bushes are usually not expensive and they look like they are past their best, so it would be worth doin.
    Reaper
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I have the same problem. All the rear bushes are fine. I'm thinking it's something to do with the uni joints or cv joint.
    VR-S series II
    Jul 2009
    Darwin
    hey mate
    im not 100% but i think its one of the uni joints for the tailshaft.(fixed this same problem on VL comme) start your car HOLD THE BRAKE get a mate to lie next to your car and put in gear to try pin point were the clunk is coming from dont run ur mate over, chances are one of the uni joints are stuffed maybe the one that joins the tailshaft to the diff.
    as i said im not 100% but worth a look
    hope this helps ya good luck
    vs clubsport
    Aug 2008
    i called up to get a price on the inner and outter trailing arm bushes done
    price fitted $475
    pedders quoted $800 fitted
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    how hard would it be to do yourself, do u have a haynes manual? i got the same symptoms and its annoying as hell
    Dec 2008
    Prick of a job, that's why it's so expensive just to change some bushes. You can do it yourself with a puller made from threaded rod, some nuts and washers and a peice of pipe.
  1. Harmonic Balance in Motor/Drive Train in a 5Litre
    By VTSSDUDE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2009, 11:01 PM
  2. Check drive train (possibly caused by new exhaust?)
    By DARK SIDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2009, 11:27 AM
  3. slight engine clunk, help???
    By 88_vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2008, 04:46 PM
  4. VT drive train conversion
    By jessedevery in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2007, 11:04 AM
  5. wrecking vn calais 5ltr + vs v6 complete drive train fs *motor, box etc
    By petezor in forum Parts And Other Items For Sale
    Last Post: 28-08-2007, 09:46 PM
