hi
ive got a 1996 vs manaul v6 exceutive and today when i was taking off in first and during 1st gear it was very slugish and jumpy! is it missing??
what do you reakon it could be??
spark plugs and leads??
distributor??
cheersss!!![]()
Could be one of many things - do a fault code check first to give you an indication. It takes only a minute to perform...Checking error codes VR/VS (Revised)
i did the fault code check came through 12 three times soo all that seems fine
thankz heaps neway mate!!!!
Maybe a bit more info - does it happen when hot/cold, does it jerk or just feel doughy, how is it in other gears and finally have you been doing any work on it recently.
does it when it gets to bout half on temp gauge
slightly jerky very doughy
all other gears are fine atm
no work done recently
spoke to my old man and he reakons to do the spark plugs and leads and then it should be fine
