Results 1 to 3 of 3
Thread: Code 44 - Oxygen Sensor Lean (O2)??
    Aug 2008
    Default Code 44 - Oxygen Sensor Lean (O2)??
    have a VS ute with a v8 auto
    it has logged this code? should i replace the sensor itself?
    or is it something else as in the tune?
    it is also a dual fuel car. running on gas
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd erase the code and try again in a week (unless the engine is missing). The sensor is probably OK - it's just reporting what it's found....maybe a blocked injector or maybe nothing.
    Just re-read your post - if it's happened on gas then someone else might have a clue....but first I'd erase the code and check later.
    95 vs calais V6 Auto
    Aug 2009
    Dora Creek
    My mates rodeo thats on gas had the engine light come on so his house who is a mechanic for holden took it to work and ran the diagnositics on it, it came up with a faulty O2 sensor and he just made it so the light wouldn't come on anymore and told him not to worry about it, he said that it might just be the gas throwing it out. but as hako said erase it and see if it comes back it could just be an old code.
  1. fault code 13: oxygen sensor?
    By sparra_gump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2012, 07:08 PM
  2. code for oxygen sensor.what should i do?
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2009, 07:53 PM
  3. code 44 oxygen sensor lean
    By Vt-Brrrlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2008, 03:25 PM
  4. code 13 oxygen sensor
    By 8vl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2008, 01:25 PM
  5. No oxygen sensor signal code
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 07:08 PM
