Results 1 to 10 of 10
Thread: engine knock on increased RPM
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    Default engine knock on increased RPM
    unsure what to do. when idling it sounds ok, but when increasing rpm you can hear a knock coming from the 'centre' of the engine. anyone had this problem, dont know whether to replace engine, fix or sell? please help
    vs clubsport
    Aug 2008
    i think might be ur engine mounts maybe even gearbox mount
    i had this problem ended up being sagged engine mount also upper bushes
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    maybe your knock sensor, i think they set a fault code. when you hear the sound does the engine make a sound as if something mettalic is in the combustion chamber?
    VR Berlina S2
    Aug 2009
    could be a bearing.
    selling vp calais wheels with 97% rubber hardly used!
    VT spac super6
    Nov 2008
    Riverton sa
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the car has 300,000KM or more then it could be the balance shaft bearings. Is it noticeable when driving or just with the bonnet up?
    Mar 2009
    it has done 216,400. you can hear it when ur driving and with the bonnet up. i had it checked and they said it could be a piston. gudgeon pin or something like that. but they didnt take the engine apart, just a guess with the stethoscope. would it be better to buy a 2nd hand engine to put in? or fix it or sell?
    HICOMPVN's Avatar
    HICOMPVN is offline Wanting That Lil Bit More
    VN Commodore Executive S1
    Mar 2006
    S.E SUBURBS
    yeah could be bearings, bottom end, con rod or balance, my buick shat conrod 3-4 at 314,000, get a second hand engine from centre rd wreckers
    Mar 2009
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Get them on ebay all the time i got one for my wagon 2 months ago for $250
  1. increased fuel consupmtion
    By nemesis_adrasteia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2009, 05:41 PM
  2. Engine knock
    By MG's VH Wag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2009, 08:50 AM
  3. Knock in the engine
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2007, 11:20 AM
  4. Engine Knock
    By BeastVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2006, 09:47 PM
  5. knock in engine
    By stockvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 09:06 PM
