I found this on the backseat lol I have no idea where its meant to go. But by nippon denso I'm guessing its the a/c or something? my a/c doesnt blow cold air. compressor doesnt even sound like it turns on
also did diagnostic test and got error 4 and 7. as there were 4 fast burts pause then 7 fast bursts after the 12 code.
I also cant get the code for the abs![]()
any relays missing in the box under the bonnet ? maybe its just a spare, i know ive got stacks floating around myself.
thats error 47 by the way.
47* 18X Reference Signal Missing.
from
http://www.users.on.net/~nweber/comm....html#vs-codes
from here http://forums.justcommodores.com.au/...ing-questions/
it means crank angle sensor signal missing
code 47 - 18x reference signal missing has to do with the crank angle sensor. You will probably need a new one soon. Noticed any stalling lately? I would probably change the CAS before it leaves you on the side of the freeway one day. Could be the DFI module, but they dont fail often, CAS's do.
being nippon denso most likely not out the holden
no stalling. I've only driven it inside the garage since I got it. I'll try and take a vid later as its hard as to explain.
But it doesnt do the tens and ones beep. Just quick 4 then quick 7 thrice.
But alas if it is code 47, how do I go about changing the CAS on a vs v6?
ok had a read and i might check the coils out first. the car has been parked up for a while so I'm gonna need to change that out anyway. she hesitates when first started. and under heavy acceleration (although only tried in first gear which is all i can get in the garage) she shakes a bit. no backfires though. Probably bad connection or dud lead. will try that and hopefully it fixes it!
that relay might be of a toyota? do u know anyone who owns a toyota with a missing fuse :P
