Results 1 to 6 of 6
Thread: axle tramp issue on vs 5.0l irs
    vs clubsport
    Aug 2008
    Default axle tramp issue on vs 5.0l irs
    hey guys this is driving me insane with the axle tramping does it when its warm also
    i notced when the cars cold and im taking off in 1st gear then i back off then back on the throttle quick i get axle tramping also its bad in peak traffic 1st gear going to around 3.500rpm then backing off the throttle until she drops around 20 to 15 on the speedometer it axle tramps about 2 times meaning 2 tramps
    where do i need to start looking some of my bushes have been changed to nolathane aswell
    VS Berlina 3.8
    Dec 2008
    Do you really need two threads? - axle tramp on vs clubsport irs
    So it only does it when it's cold? If this is the case, it might be something further up the drive shaft.
    Get under your car and start checking your bushes. There is a very large one behind the diff, give that a good look over.
    vs clubsport
    Aug 2008
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    i work at pedders i see this all the time go to your local pedders there is three bushes in the back that control tramp
    vs clubsport
    Aug 2008
    vs clubsport
    Aug 2008
    control arm inner and outer
    crossmember mount outer and crossmember mount outer spacer
    diff mount insert
    i got quoted $475 supply and fitted?
  1. Axle tramp issue
    By 6 shooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2008, 06:40 PM
  2. axle tramp
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2008, 05:07 PM
  3. axle tramp?
    By vn calais manual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2008, 04:34 PM
  4. Ute axle tramp
    By Barcode in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-12-2005, 11:39 AM
  5. Axle Tramp
    By GAMWARDO in forum General
    Last Post: 28-10-2004, 11:26 AM
