Results 1 to 13 of 13
Thread: VS Trans cooler
    VS Equipe
    Oct 2009
    Default VS Trans cooler
    Just bought a VS V6 and will be using it for towing a 14 foot boat. Someone said it's a good idea to have a trans cooler on these boxes. What are the pbr ones on ebay like? does any have any suggestions for me .
    Thanks.
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    dont know about the pbr one's
    but i cooked my auto early this year driveing from canberra to grenfell in 40deg day got back same day and it was ****ed changed the fluid and filter twice now and it's playing up again
    save the money and by a cooler
    vp executive wagon
    Oct 2009
    A.C.T.
    i am getting a new box soon btw so this is what happens to you if you get caght out
    VS Equipe
    Oct 2009
    Quote Originally Posted by dynoryder View Post
    Nasty!! Sounds expensive
    vp executive wagon
    Oct 2009
    A.C.T.
    yea vp boxes recoed are bout $1800 im a mech so i have some contacts im getting one for bout $900
    VS executive
    Jun 2009
    how far is that, ill be doing country trips a fair bit this summer.
    vp executive wagon
    Oct 2009
    A.C.T.
    bout 300k there 300 back so 600km in a day with a rest after 300
    but changeing the filter and fluid helps alot to but cooler is way to go it helps cooling in two ways it radiates heat out of the box and increases the oil volume
    in an engine oil volume is desireable
    vs executive s1/ vz berlina
    Mar 2008
    Quote Originally Posted by hespie View Post
    Thanks.
    Derale brand, US made have all the accessory on it, we use a lot of these on the shop. i think you can get this form burson or your local auto supplier.
    VR Berlina S2
    Aug 2009
    VS commodores usually has a trans cooler.
    my mates acclaim has a stock cooler.
    selling vp calais wheels with 97% rubber hardly used!
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    VS series 2's came fitted with a cooler as std but they also had screwed fittings, I think the series 1 vs has push on fittings same as VN-VR.
    Try the Holden max towing pack cooler, don't know if available still but when I bought mine years back was cheaper than PWR and Borg warner models of similar size.
    I used the large one for my auto and used the small VN-VR cooler for my power steer cooler.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VS Equipe
    Oct 2009
    Quote Originally Posted by Surfwagon View Post
    Thanks for that very helpful.
    VN SII
    Jul 2005
    Altona
    use a trans cooler from a vt on wards they are bigger then a vs cooler and are better
    vs commodore
    Oct 2009
    Tamworth NSW
    Id keep the auto serviced regularly,filter etc as well as a good cooler.It should help to make it last.Its somthing people forget about until they notice somthing wrong with it.A mate tows a work trailer around with his VS ute,its fairly heavy and hes had a good run out of the trans ,he just keeps it serviced etc.
  1. VR trans cooler.
    By BONSVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 10:38 AM
  2. VY OIL Trans cooler
    By klone74 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-09-2009, 10:01 PM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. V8 trans cooler on a V6
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2007, 08:20 PM
  5. VR Trans Cooler
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2005, 10:54 PM
