my brother front bearings are gone on his vs, he got bugga all cash an was thinking i got some Vy hubs that were strip from my ute, would this bolt in? cause at the same time he can fit the vt twin pot caliper
cheers
in life some people need a little guidance, others just need a good kick
if the abs is the same and they fit the knuckle then why not but if i rember corect it cant be done
his car non abs, cheers might have to strip his car down an have a good look
Wont fit... as i try it on my vr for Vy hub .. but wont fit ...
had a look today the only difference i can see is the ball joint conection, gonna strip down any way cause its stuffed but while i'm there will have a better look
cheers guys
you mean knuckles not hubs mate no nuckles can not be changed
going by the book they call it ball joint, but either way i'm not fussed cause its not my car getting stripped![]()
the ball joint bolts into the knuckle by tapperd contact the hub bolts to the knuckle via three inhex bolts
