Results 1 to 3 of 3
Thread: VS Airbag steering wheel puzle
    VS commodore ute Series III V6
    Sep 2009
    Townsville NQ
    Post VS Airbag steering wheel puzle
    Hi guys,
    If anyone could tell me will a VS commodore Airbag steering wheel bolt onto the spline of were a Non airbag steering wheel was.
    If so does the drivers side airbag unit unscreew and come off as one piece conected to the horn pad so that the steering wheel is left. Or is the airbag unit conected to the steering wheel itself.
    I want to know if the airbag unit can be thrown away and the steering wheel used by itself as a Non Airbag wheel to use in my ute.
    If any of that makes any sence.
    cheer shaun.
    Attached Thumbnails Attached Thumbnails VS Airbag steering wheel puzle-img_2811.jpg   VS Airbag steering wheel puzle-img_2847.jpg
    VS Acclaim S2
    Sep 2009
    The splines on the shaft are the same regardless of whether an air bag is fitted or not.
    To remove the air bag from the steering wheel you will need to remove the air bag fuse and then remove the torx bolts at the rear of the air bag. Then you will have to disconnect the wiring before taking out the air bag assembly.
    Sep 2009
    Townsville NQ
    Thanks for that Jedlee
    Thats what i needed to know/here.
  1. [QLD] vy/vz steering wheel airbag
    By kego in forum Swap / Wanted to Buy / Trade
    Last Post: 27-06-2009, 07:45 PM
  2. new steering wheel + airbag
    By dmar in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-05-2009, 10:25 PM
  3. VS Airbag Steering Wheel
    By HamaTime™ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2009, 02:59 PM
  4. VS Airbag Steering Wheel??
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2006, 10:30 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
