Hey guys having a problem with my indicators at the moment when i go to put them on all my indicators light up ive checked the fuses and put a new flasher relay in and still hasnt solved the problem anyone have any ideas?
thanks
I know a buggered hazard flasher switch can cause this problem although if it hasn't been touched it should not have failed. Have any mods/alterations been made under the dash lately?
could be a prob in the switch itself
i havnt touched under the dash im going to have a look at the stalk today see if theres anything there if nothing there then ive got no idea thanks guys
Like I said previously - it could be the hazard switch buggered - the indicators go thru this switch. Check by pressing hazard switch on/off a few times and see if it makes any difference.
check your indicator stalk itself, may have gone. does your cruise control still work?
i pulled the indicator stalk out ive fixed the prblem sort off i realised if you move the steering column sometimes it works sometimes it dont but at the moment all is good thanks guys
