+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: Cruise control not working
    VS Equipe
    May 2009
    Default Cruise control not working
    Pretty self explanatory.
    VS V6 Equipe
    Cruise light on dash doesnt light up at all
    any suggestions?
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    First thing is to check is that you don't have a burnt out brake light - this will stop the CC from working.
    VS Equipe
    May 2009
    VS Equipe
    May 2009
    88GreenVN's Avatar
    88GreenVN is offline Almost not here! 88GreenVN W427 88GreenVN W427 88GreenVN W427 88GreenVN W427
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Set the brake switch if it's moved.
    http://forums.justcommodores.com.au/...ake-switch.jpg
    and 3 Dangerous non ABS VN's
    VY SS
    Jun 2006
    Albany
    where did you get this info? cruise has nothing to do with the brake lights as the cruise system has its own separate switch for the brake pedal.
    Cruise light on dash doesn't light up at all
    which light are you talking about? Cruise or On? if its "Cruise" that's not coming on maybe check your fuses. if it the "On" light which comes on when cruise is activated is not coming on it could be a faulty indicator stalk which has the switch inside.
    VS Equipe
    May 2009
    88GreenVN's Avatar
    Jun 2006
    It can be 2 things most often, the brake switch or the motor control thing.
    It the brake switch is not working the system WILL NOT engage.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    [QUOTE=axemurderer101;1316911]where did you get this info? cruise has nothing to do with the brake lights as the cruise system has its own separate switch for the brake pedal. QUOTE]
    The separate (fail-safe) cruise brake switch is in addition to the standard brake switch - in other words the CC relies on 2 brake switches. Pages 282/283 of Gregorys workshop manual describes them - that is the source of my info.
    VY SS
    Jun 2006
    Albany
    VS Equipe
    May 2009
    CC switch working fine and i took it out and set it properly
    its a brain teaser
    greenacc's Avatar
    greenacc is offline Searching for the billion greenacc Calais
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    It was the buttons on the stalk that cuased this problen on my car last week.
    I replaced the indicator / cruise switch with a new one and cruise works again !!
    VS Equipe
    May 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also check the CC relay is working - substitute it with a similar nearby relay. I got my indicator arm from a wrecker - $35
  15. #15
    greenacc's Avatar
    VE Berlina
    Jul 2008
    do all your checks before you go shopping as Hako said, ... a new stalk from Holden was $78. I've heard you can pick these up cheap on ebay and similar places but i was on holidays and wanted to fix it so i could cruise home lol.
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
  17. #17
    VS Equipe
    May 2009
  18. #18
    VS Equipe
    May 2009
  19. #19
    greenacc's Avatar
    VE Berlina
    Jul 2008
  20. #20
    VS Equipe
    May 2009
    yea relay working fine also
    i will pick a new indicator stalk up from the wreckers
  21. #21
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    When you pick one from the wreckers try to get one with legible letters on it - this is usually an indication that it's from a low mileage car.
    Just before you go spending $$$ on an indicator, try bridging the terminals on the CC brake switch (the top one) - it can appear to be set correctly but unless you either test it with a multimeter or bridge the terminals you cannot be sure it is correctly set.
  22. #22
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member VS_Pete_1 Berlina
    1997 VS II V6 Berlina Auto Wagon
    Dec 2007
    [QUOTE=hako;1317320]
    Quote Originally Posted by axemurderer101 View Post
    Not that I disbeleaved you hako just had a look at the Gregorys you are spot on mate.
    One thing I do know is you don`t post rubbish and always give good advice and try to help members out with their problems you are an asset to this club.
    Good on you mate.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
  23. #23
    VS Equipe
    May 2009
  24. #24
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Crossy_014 View Post
    nah tested it with a multimeter
    Was the CC switch open or closed circuit when tested with the brakes off? - reason I ask this is that it works opposite to the brake switch which tricked me when I first installed cruise.
  25. #25
    Brett is offline Legend Brett Executive
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    I recently had the same problems, first problem was the blade fuse under the dash was blown causing nothing to light up or work, replaced it and all lights came back on but the cruise wouldn't engage, so I adjusted the brake light pedal switch and was good. Btw my relay is in the BCM.
+ Reply to Thread
  1. cruise control not working -vr
    By stormsearcher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2010, 09:05 AM
  2. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 11:25 AM
  3. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 09:41 AM
  4. VT cruise Control not working after lights turned on
    By Legman_oz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2009, 07:53 PM
  5. Cruise Control not working
    By Ray De Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2009, 03:40 PM
