Results 1 to 2 of 2
Thread: VR Vapour hoses (filler neck)
    Jan 2008
    Default VR Vapour hoses (filler neck)
    Hey guys, my vr doesn't have ANY hoses connected to the filler neck, i see there should be 4, three smaller hoses, and 1 large hose, is anyone able to confirm the right position where theses hoses run too.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    This is something I dug up some time ago.....talks about the breathers and where they go.
    Here is a copy of a post by kartbro that covers it all....so credits to him:
    Post VR Commodore Breather Hose How-to.
    Breather hose How-to for VR:
    Drive until the tank is near empty!
    Undo the wiring from the front of the tank. Also undo the fuel hoses (Not 100% neccessary unless but you want to clean the tank while its out), otherwise bend open the metal straps holding the metal fuel lines to the car, to allow the hoses to move down with the tank.
    Remove the panel at the back of the Drivers side rear wheelarch. (Need stubby phillips) It will reveal the filler neck assembly.
    Next, loosen the filler neck at the rubber hose that joins it to the tank. (I left my filler neck in throughout the process but you could take it out for cleaning) Pull off the two breather lines that attach to the bottom of the junction box that lead to the tank.
    Put two jacks under the fuel tank between the straps. Try to positon for best weight distribution. (on diagonal ends of the tank) Wind the jacks up until they contact the tank.
    Undo the two straps at the rear with a 17mm ratchet or spanner. (No need to undo the front of the strap it just makes life harder!) They will peel from the tank. Start lowering the jacks until the tank is being stopped by the filler neck connection. A bit of brute downward force will dislodge the tank. Lower the jacks further until the whole tank is free. At this point i pulled the jacks out from underneath and slid the tank out on the straps.
    I poured the remaining fuel in the tank into a jerry can, (with assistance) and used some to clean the exterior of the tank. Make sure the filler connection is very clean. (No dirt in tank on reassembly, this is why the tank was completely removed...). Pour some petrol back into the tank, and shake it around inside to dislodge any crap inside. (Assistant comes in handy here too) Pour it all out and repeat.
    Clean the filler neck and replace the breathers on it. There are 3 connections at the top of the spout. Two of them go straight to the top of the junction box. The other goes to the Evaporative Emmisions Control System. (Sucks up petrol vapours and burns em...) This is one of the three metal pipes running the length of the car, two go to the fuel tank, the other should terminate somewhere near the filler neck.
    By this stage the tank should be ready for installation... You will now also need 1 metre of thick hose. I couldnt get any of the stuff holden used so i used some heater hose. Apparently this will handle fuel. (Guy at Bursons told me so it has to be true!!)
    Attach some more than long enough lengths of small and large breather hose to the tank. Slide the tank in on the straps. Feed hoses through the chassis rail. Put your lowered jacks in underneath the tank.
    Raise the tank slowly and make sure the hoses are feeding through the chassis correctly. Make sure the filler neck is mating with the tank correctly (Lube helps here!) Everything should go up nicely. Make sure the hoses arent crushed by the pads on the top of the tank.
    There is a slot in the seam of the tank at the rear on the drivers side. There is a small tab from the chassis that slides into it and guides the tank into place. Refit the straps loosely and remove the jacks. Check your filler neck is in place and tighten it to the tank. Check for correct fitting through the filler hole also. Tighten the tank straps.
    Reattach hoses and wiring to the front of the tank. Cut the loose breather hoses to length, add a little extra to allow shrinkage over time. Attach to the bottom of the juncton box. Cut the thick hose to length and attach to the top of the filler neck. Replace the inspection panel in the wheelarch. Bend back the metal straps holding the fuel lines (if you loosened them) Put about 15 litres of fresh fuel into the tank and check the filler isn't leaking. Turn the key to ignition and back a few times to prime the fuel system. Job done Good luck.
    Hope I remembered it all!
  1. Hoses from the filler neck: mix and match!!
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2008, 02:54 AM
  2. Vapour gas on v6 - experiences pls
    By bajdas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-08-2008, 09:04 PM
  3. VT gas or vapour entering cabin
    By Cappy1997 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2008, 11:05 PM
  4. WTB: VN Tow Bar neck
    By 05 VZ SS in forum Swap / Wanted to Buy / Trade
    Last Post: 01-05-2006, 08:48 PM
  5. VL fuel vapour hoses. Where do they go?
    By Peterb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2005, 07:07 AM
