Results 1 to 6 of 6
Thread: VS S pack S1 with S2 options???
    vs wags
    Jan 2009
    Default VS S pack S1 with S2 options???
    gday all.. i recently purchased a manual vs s pack in panther mica. its registered as a 95 although im not 100% sure it is.
    things im suss about:
    -its got electric windows &mirrors which im told were only in the S2's
    -its got oval clear side indicators... could be aftermarket i guess but im not sure.
    -its got IRS & ABS... not sure if it was avaliable in S1's but i think its pretty rare in s packs.
    -clear rear indicators... i guess could have been off a calais/berlina.
    -has colour coded mirrors
    -also has driver and passenger airbags.
    does anybody know a way i could definately clear this up? cheers
    Quote Originally Posted by Burns48_VR View Post
    Hey guys i was painting a set of interceptors and i got some of the silver paint on the wheel, just wondering if anyone knew of a good way to get it off or to cover it up??
    Quote Originally Posted by jamaar4 View Post
    Learn some can control toy
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    probably the only way you're going to clear that up is to ring holden with the VIN. All of those things could be optioned right through the series, so you wont be able to tell that way.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS Berlina 3.8
    Dec 2008
    All of those are S1 options too. Side repeaters are easy to replace. Just about all of those options go back to at least the VP. ABS came in with the VR I'm pretty sure, IRS has been around since the VP.
    VS S Pack
    Sep 2009
    I have a Apr 95 VS S pack and it has power mirrors, ABS, IRS but no air bags so I agree that they were all options
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by _R_J_K_ View Post
    IRS was first introduced on the VQ statesman, but prototyping began in the VL, I believe the first two HDT directors were the only ones built with IRS.
    Also ABS was introduced in the VP series
    Power is measured in DECIBEL
    vs wags
    Jan 2009
    true, must be a s1 then. ill ring holden anyways n check. cheers fellas
  1. 96 vs 5.0lt options
    By timgray in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2009, 10:56 PM
  2. considering my options
    By nemesis_adrasteia in forum General Discussion
    Last Post: 13-05-2009, 12:49 AM
  3. lsd options?
    By berlinabeast in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-05-2009, 03:24 PM
  4. VX options
    By roger05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2006, 08:01 PM
  5. options
    By 3800_man in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-05-2006, 07:31 PM
