hey guys.
I still cant work out my problem so i better post it here.
My drivers side power window moves around when going up and doesn't sound good.
i can't shake the glass in the passengers door glass but i can with the drivers side one (the problem one)
any help will be great!
thanks!
selling vp calais wheels with 97% rubber hardly used!
Sounds like it's come out of its rails. Take the door trim off and see if you can reposition it.
Could be a broken nylon runner, $3 or $4 from Holden.
MY RIDE
could also be the rivets letting go....rerivet or drill them all out and put screws and nuts in their place
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
Remove your door trim... there is a how to for that somewhere here, and you should be able to find and fix your problems pretty easily.
yeah i did that ^^
Found out it was a bolt that has a smooth top so i cant tighten it back into position, so i took it out, cut a head into it, and now it wont screw in anymore and it aint tight and holding the power window assembley
