hey i've gotten a VS airbag that came with the steering wheel i brought and was wondering if could put it in my VR Calais since mine has a hole where the horn pad is, just thought id ask before trying in case it decided to detonate or somthing, thanks.
You'd need to check with GMH that the VR and VS airbags are identical otherwise it may be incompatible. If they have the same part number it may be OK but I'd triple check. If you do remove the old airbag make sure you follow all the safety rules (google it)
all of the inner workings are the same, only difference is the holden emblem on the cover. 96 onwards VS has small dimples around where the horn buttons are as well.
but to answer your question, it will work the same as the original VR one.
