Results 1 to 3 of 3
Thread: vs v6 running like a pig
    vs v6
    Oct 2009
    Default vs v6 running like a pig
    vs exec surged then stopped checked the usual stuff . To cut a long story short replaced with new. iac, dfi, coil pack ,fuel filter ,tps, crank angle sensor, still stuffed need help any ideas? p.s. it starts after some cranking over but runs badly , i can keep it running only by playing with throttle.
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    Maybe check the codes on your car first?
    Checking error codes VR/VS (Revised)
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    fuel pump? spark plugs or bad leads? check codes first as mentioned before
  1. not running
    By icwoodsy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2007, 07:29 PM
  2. Running in oil??
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-03-2007, 08:37 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. VN not running on all 6
    By brotton1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2006, 11:49 AM
  5. v6 only running on 5
    By vnrock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2005, 01:58 AM
