Results 1 to 4 of 4
Thread: central locking question
    Sep 2008
    Gold Coast
    Default central locking question
    if i don't lock the car after starting the car the vibration from the plastic bit that pops up from the doors is very noisy can this be fixed all do i need a new central locking kit
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    By "vibration" do you mean the actual lock button or squib is being electrically forced to "vibrate" by the central locking solenoid or is is just loose and shaking?
    Sep 2008
    Gold Coast
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You'll need to remove the door trim to inspect the actuator (which forms part of the door lock mechanism - check if it's loose or otherwise damaged and also check the wiring connectors. To replace just get one from a wrecker although the vibration may just be caused by a loose control rod which you can fix. You may need to drive the car with the trim removed to rty and duplicate the fault.
    Search the "how-to" section in the forum for the details on pulling the trim off.
  1. Question about immobilser/central locking in VS Series I Ute
    By VTSSDUDE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2009, 09:12 AM
  2. Central locking question
    By fatboy15 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-03-2009, 10:39 AM
  3. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  4. Yet another central locking question
    By KiwiHoldenDriver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2008, 01:50 PM
  5. Vp central locking
    By adam69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2006, 10:31 PM
