Hey everyone,
im looking at converting my series2 vs acclaim to a manual.
i was wondering if u could put the vt/vx/vy conversion in?
if not why is that so?
does the gearbox not fit?
i know the computer woudl be different.
but help woudl be much appreicated??
Can change your car to Manual. What gearbox are you putting in ? Getrag from a VT-VX ? if so you'll have almost everything you need to make it all work. Only thing left will be a memcal to suit. Getrag use a 2-wire speed sensor and your existing ECU will work fine.
EDIT: Wiring mods will be required though.
VN - VY V6 Kalmaker tuning.
The wiring mods are VERY simple however, check out the manual conversion guide in the HOWTO section, it doesn't list that it applies to a VS, however the wiring info provided IS relevant.
Give someone like delcowizard, ejukated or greenfoam a yell and ask them to make you a memcal for your Auto ECU that will suit a manual conversion, they should even add a few tweaks to give you some extra performance too.
Maybe the hardest and most expensive item to come by will be the manual pedal box. ppl don't like to sell them seperate from the rest of the bits and the VT one is very different from the required VR/VS one.
yeah i have my eyes on one at the moment all that is missing is that tailshaft.
and the computer would need a new computer casues its for a vx.
so its got clutch flywheel and pedal.
but i was just posting this thread to make sure the vx box would fit before i go ahead and do it all.
cheers
Yeah, holden has got you over a barrell there. The wiring can be modified to accept a VT V6 ECU then a EEPROM to suit will be a walk in the park.
Thats awesome.
cause im sure i would of figured out all the wiring and what not.
it was just making sure the box would bolt up
anyone going to tell me it cant be doing before i go and do it just to be positive and not wasting my tiem here???
thanks
