Past few days my vs has been ideling really weird. On a cold start its fine but after im driving for a bit and pull up at the lights and wait a bit it starts to drops rpm and sounds like it spits a bit when doing so too, then once it does that the engines goes back to normal then starts again. I have also noticed too that when i go to plant it sometimes the engine like cuts out then goes back to normal......
Recently i just got a new fuel pump installed few days before this started.
mechanic did it. i got spare coil pack for it so yea ill try that. I also put in a more updated computer the other week too. I took out my BSTK ecu and replaced it with the BWPJ ecu.
the mechanic is a family friend but it started playing up probably about 2 days after i got it back
Could be a blocked fuel filter....and I'd also be a bit sus about the swapped ECU.
i changed the coil packs today and reset the ecu. Seemed to be fine for the first 15mins then back to ideling funny
Not the coolant temp sensor? - the one that tells the ECU the engine is hot and to lean the mixture out? Maybe put the original ECU back in. DFI module could also be bad.
