Results 1 to 2 of 2
Thread: big knocking noise, occasionally!
    vl & vr commodore
    Oct 2005
    adelaide
    Default big knocking noise, occasionally!
    Got a vr v6 done 200,000kms, change oil regularly etc, lately have noticed when its been driven for a long period , & hot , there is a knocking noise coming from motor, sounds like noisy lifters , but only does it when its fairly warm. Any suggestions , or have i answered my own question & should i just put some lifter stop noise through the oil or what??
    or could it be somthin worse??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Probably just piston slap or wrist pin knock - either can be evident on a hot engine and the sound will come and go, sometimes louder then quiter then louder - it's usually noticeable at idle when hot...no real drama. You should be running 20W50 oil - anything thinner will invite rattles. Lifters that tap usually tap hot and cold so it's probably not that although adding some lifter quitener cannot do any harm (it just thickens the oil)
    At your mileage the motor should still not be using any oil between changes but it is getting on and you've got to expect some noise from the engine but I wouldn't worry about it unless it changes dramatically.
    Good Luck.
  1. Knocking Noise from under the car.
    By SoulGrind in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-07-2009, 09:59 AM
  2. Knocking Noise
    By fitz_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2009, 09:45 PM
  3. knocking noise on take off only
    By tenggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2009, 04:08 PM
  4. knocking Noise
    By fudlop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2005, 06:02 PM
  5. Knocking noise
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2005, 07:14 PM
