Hi just bought a vr 5.0 and it holds gears until your high in the revs.. checked for kick down clable and nothing so is it electric and is it adjustable or would it be a vacuume type problem?
Only Oil Comes In 4.0 Litres
shunt it into park, at freeway speed ? .. LOL hi rob
What are you calling high revs?
I dunno i guess 3/3500 then holds but if you get up to 70/80kph it'll change.
changes hard to
Its either the pressure control or burnt friction cluchtes that could be the problem,
How is the motor running? Any problems with it?
Friend has a VS 5L and had a similar issue. Discovered to be the fuel pump on its way out and the computer telling the gearbox to hold the gear for an unusual amount of time.
JCCC NSW Member
Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
Just Commodores NSW Chapter. Join in for a cruise some time!
Click here for more info
bad TPS or larger throttlebody could be a possible.have you checked for error codes at all allways a good place to start
