Results 1 to 9 of 9
Thread: fuel gauge problem
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default fuel gauge problem
    past few weeks we have had a issue with the vs and fuel guage not working,
    just stopped all a sudden
    its factory fitted gas which also uses the clusters fuel gauge when switch from either fuel
    it has been up graded too level3 cluster which had been fine for past few years now
    so to get me by while i was focusing on my vl i was checking the fuel levels digatally to see whats in the tank
    but then thats stopped too and said there full on max...... check the manual gauge on the actual gas tank and that doesnt show the fuel which the cluster has
    DTE is just saying flat 400km and not moving
    i dont think it would be the fuel sensor in the petrol tank as it doesnt work on the gas either, it would be strange for both to fail at same time too.
    would this be the cluster more then likly or is there something else i could look at??
    i have access too a spare cluster if need be too try,
    cheers
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If it's saying full tank - press and hold set button to show how much the tank has in it.
    If it says full then I'd say the sender is at full ohms or voltage - what ever they use to work LOL.
    Or the voltage regulator is caktus and the other cluster will tell you this in an instant.
    and 3 Dangerous non ABS VN's
    Oct 2005
    cheers for that Shane
    yes, when i hold set on the fuel avg one it says 60.0ltrs in the tank for both fuels
    but the needle reads empty, like ignition turned off empty
    suppose ill swapsie and see then
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    88GreenVN's Avatar
    Jun 2006
    I have a heap of spares to fix anything within the cluster if you need anything.
    It's almost as if the sender is stuck on full AND the regulator has a cracked solder joint. Will it move if you tap the dash?
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    Oct 2005
    nope
    dash bash was my first fix job attempt but didnt work
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    88GreenVN's Avatar
    Jun 2006
    The regulator in the cluster tends to fail a little more each time rather than instand dead. (is solder joint)
    So could be a risistor thingy gone legs up
    Oct 2005
    well ill try cluster swap first then i might hit you up if your intrested shane in a repair
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    88GreenVN's Avatar
    Jun 2006
    If it's anything to do with the cluster - easy done
  1. VZ Fuel Gauge Problem
    By David B in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-04-2012, 09:54 PM
  2. fuel gauge problem
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2009, 10:13 AM
  3. Fuel Gauge Problem
    By Brocko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2008, 05:12 PM
  4. Fuel gauge problem !!
    By kowan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 11:47 PM
  5. Fuel gauge problem.!!!
    By shiftyvin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-07-2005, 10:05 PM
