Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: diff gears but keep top end speed... v6 getrag
    A bicycle
    Aug 2009
    Gippsland, Victoria
    Default diff gears but keep top end speed... v6 getrag
    g'day g'day,
    as i am planning to take the ute to the racetrack for some legal fun, i know its underpowered and underbraked but its the only was to have some fun and not go to jail these days, i've decided that before i go, a diff gear swap is in order, along with an lsd centre or mini spool. mini spool is cheaper but its not road legal.
    so i'm going to go from the standard 3.08 ratio to something a bit shorter, as using my tyre size (235/45 17 inch) and a 5500rpm rev limit (im not sure what the ecotec revs to, i dont have a tacho =(, theres another job) gives me these theoretical speeds (wont be accurate due to possible clutch slip and ballooning of tyres)
    1st: ratio 3.829:1 - 56.53 km/h
    2nd: ratio 2.199:1 - 98.44 km/h
    3rd: ratio 1.401:1 - 154.51 km/h
    4th: ratio 1.000:1 - 216.47 km/h
    5th: ratio 0.809:1 - 267.56 km/h
    not sure if i did this right, but it should sit at 2055 rpm at 100 km/h in 5th gear..
    now i know that the V6 will never get that speed in 5th gear, which is kind of a waste, but i'll still need it to be reasonable for highway driving so was thinking about a 3.55 ratio rear end. speeds are:
    1st: ratio 3.829:1 - 49.05 km/h
    2nd: ratio 2.199:1 - 85.41 km/h
    3rd: ratio 1.401:1 - 134.05 km/h
    4th: ratio 1.000:1 - 187.81 km/h
    5th: ratio 0.809:1 - 232.14 km/h
    and will sit at 2369 rpm at 100 km/h.
    would this ratio be a fairly good compromise, if my calculations are in the ballpark, it seems reasonable for the lack of engine power etc.
    opinions?
    this swap is looking close as i have a nice diff oil leak that needs attention, so might just do it at the same time.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    A bicycle
    Aug 2009
    Gippsland, Victoria
    no thoughts??
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    it's either 3.45:1 or then 3.73:1 (rear as hens teeth though). i have the 3.45's in the VN. pickup is better and i honestly think it's made stuff all difference to fuel consumption. really depends on how you drive it
    can't for the life of me see why holden used the getrag with .80 OD ratio. the old T5 with .72 OD ratio did fine and only did 1800rpm @100km/h.
    Body by Holden, Soul by Brock
    the Legend will live forever
    A bicycle
    Aug 2009
    Gippsland, Victoria
    yeah thats true about the fuel economy, im not too stressed about the economy side THAT much. hmm i read your mega-awesome thread on diffs, am i able to get the diff centre from a 6 cylinder vl (turbo) and fit that to my rear end to get the 3.45:1 ratio?
    i suppose that the wreckers will be lucky to have a turbo diff lying around and will probably charge a mint for it though.
    Apr 2006
    Auckland NZ
    all VL's had the 3.45 ratio except the V8 models which had 3.08's fitted. so yes you could go to the wreckers and get any V6 diff and then use those gears in your diff. you could also fit the entire VL diff into your car but would still need to fit a LSD center and the VL diff is narrower then your diff so it would alter your wheel track width also.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    i'll have to swap the gears over into my rear diff, as i would have to run different offset wheels on the back as they are close to rubbing and scrape when the suspension is bottomed on one side.
    i'll hit up the wreckers after my exams and get it done.
    VS Executive 3.8 Eco
    Oct 2005
    just on the throwing a VL diff in the back end, with the extra 40mm what type of tyre widths are possible 275's?
    A bicycle
    Aug 2009
    Gippsland, Victoria
    hmm you'll be still limited on the width inside the wheelarch, i get heaps of rubbing on the inside of the guards with just 235/45's on vt ss wheels. just when one wheel gets compressed heaps on side slopes etc.
    just came across a rolled r31 skyline with a manual, might grab the diff out of it. should have looked what ratio it was. hopefully its got the 3.73 ratio gears.. bit shorter than i wanted but hey, beggers cant be choosers
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    you also need to make sure that if your car has ABS, that whatever diff you use in the rear has ABS sensors built in, unless there is a way of transferring them?
    Oct 2005
    car is as basic as they came. previous owner was cheap. no aircon no abs no irs absoloutley no options whatsoever
    A bicycle
    Aug 2009
    Gippsland, Victoria
    with the 3.73 ratio rear end and using 5500 rpm as max revs will give me..
    1st: ratio 3.829:1 - 46.70 km/h
    2nd: ratio 2.199:1 - 81.30 km/h
    3rd: ratio 1.401:1 - 127.62 km/h
    4th: ratio 1.000:1 - 178.80 km/h
    5th: ratio 0.809:1 - 221.01 km/h
    and 2488 rpm at 100 km/h which is getting up there, but not that bad.
    i used some internet calculator, so im not sure how accurate it would be.
    Oct 2005
    yeah i looked at the same type of stuff i dont think its 100%. you also have to count in size of tyres and such. but i used one of those internet calculators and put in all the stock figures of the getrag on 15inch rims and got something completely different to what my car actually says at 100kmph
    im thinking of going 3.9's with a spool so im leaving the gas system in for the long drives to save on economy.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    yeah i used one where i had to enter all my wheel/tyre info, i think its close to the mark but cant trust it 100%.
    3.9's hmm, what gearbox do you have?
  15. #15
    Oct 2005
  16. #16
    VS SS
    Jul 2009
    Quote Originally Posted by old mate View Post
    dont think thats right..
    i got 3.7s and 4th gear gets to 200 km/h with 5 speed and 18's
  17. #17
    A bicycle
    Aug 2009
    Gippsland, Victoria
    Quote Originally Posted by Vs_ss_gmtank View Post
    yeah you're probably right, but im only running 17's with 235/45's, couldnt imagine a huge difference in diameter between the two.
  18. #18
    Oct 2005
    Vs_ss_gmtank what are you sitting at rpm wise at 100kms, im thinking of doing 3.9's with 18" rims, would love to find out what 3.7's make the car sit at.
  19. #19
    A bicycle
    Aug 2009
    Gippsland, Victoria
    what size tyres do you have on your 18's mate?
  20. #20
    Oct 2005
    dont have any yet, i kinda wanna see what type of revs im gonna be sitting at before i invest in them. if i do get any though they will be something like 225/35's
  21. #21
    Apr 2006
    Auckland NZ
    there is another thead somewhere where i have all the numbers for the different diff ratio's and gearbox types. showing max speed and 100km/h speeds. CBF typing it all out again
  22. #22
    VS SS
    Jul 2009
    Quote Originally Posted by speed_freak View Post
    I sit on about 2,3k when doing 100 although my speedo is out by 20ks
  23. #23
    A bicycle
    Aug 2009
    Gippsland, Victoria
    is that a 100k's on your speedo thats out or about what 100kph is?
  24. #24
    VS SS
    Jul 2009
    the revs sit on about 2,300 rpm while doing 100mph
    and was just saying that 3.7's put your speedo out by 20ks
  25. #25
    Oct 2005
    i think what he was wondering is whether you are sitting at 2,300rpm at 100kmph (which is 80kmph im guessing) or your sitting at that rpm doing 120kmph (so actually 100kmph). id love to know aswell ive got a spooled diff in my room waiting for some gears.
  1. Hsv vs senator 6 speed manual diff gears
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2009, 06:22 PM
  2. Servicing Getrag Box/Diff
    By sweefu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2009, 08:21 PM
  3. Getrag 5 Speed, Cracking Need Help
    By pooly.09 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2009, 11:59 PM
  4. Longevity of the Getrag 5 Speed
    By bsbozzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2007, 10:15 AM
  5. Vs V6 getrag series II manual 5 speed
    By evo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2006, 09:45 PM
Tags for this Thread
