Results 1 to 10 of 10
Thread: getting very hot with a/c on
    vr calais 5ltr
    Aug 2009
    nsw
    Thumbs down getting very hot with a/c on
    as everyone would probably know by now its a V8. normal cruising on the highway it sits round halfway yesterday it was 35 degrees and sat just over half. i switched the a/c on and it went well over 3/4s before i noticed and switched it off.
    i checked the coolant levels and everything and everything is spot on. what should i be looking for? Summers coming and i will definately be needing the a/c. cheers guys
    My Ride:
    vr calais 5ltr (gone to the darkside)
    Previous rides:
    zj fairlane 351c, nf2 fairlane 302w, ef fairmont str8 6, ef2 falcon str8 6, ef fairmont ghia str8 6
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    check that the thermo itself is actually opening all the way. maybe time for a flush before the really hot weather gets ya
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    vr calais 5ltr
    Aug 2009
    nsw
    ok a bit more info on it unsure whether the a/c fan on the front of rads coming on ill check tomorrow. just over a month ago it had new rad put in and hole system flushed out. and the thermo is constantly on because some idiot has hard wired it to the battery and i havent had the chance to hook it up properly yet
    My Ride:
    Previous rides:
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I didn't think the V8's had thermostatic (electric) radiator fans...don't they have an engine driven clutch fan?....plus an electric fan in front of the radiator for the A/C.???
    GAMBLR's Avatar
    GAMBLR is online now More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    Check ya theromostat as well. With the AC system not used much during winter, it helps to check it all out before summer comes to get it working properly
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    vr calais 5ltr
    Aug 2009
    nsw
    I've checked everything and it all seems to be working properly its got me F*&#ED
    My Ride:
    Previous rides:
    VS v8 manual Calais, Ve ute, 68 Hk Holden v8
    Aug 2009
    coalville, vic
    hey mate im having the same prob just not as bad! mine sits at the 2nd- 3rd notch (from C) in 30c but then turn the aircon on sits bout the same till u stop, then slowly goes up. i did a test the otha day in drive sitting in the drive way it went to 5th notch and stayed there for 6 mins, turned the aircon on and left it in drive it went to 7th notch (3/4) in about 5 mins and then starter only slowly creeping up after another 5 mins, easy way to cool her down in the heat is at the lights put her in nutral idle her up to bout 1500- 1750 and it draws alot more air than idle does and watch the temp go down fairly quik,
    also i was looking at the thermo fan for the ac the other day and it doesnt really draw much might be worth changing it over with a more power ful one, also my aircon radiator looks a bit damaged as in the fins anrt all straight which wouldnt help prob
    vr calais 5ltr
    Aug 2009
    nsw
    yeah i think i found the problem with mine. the temp still sits around half or a touch over but the thermo fan for the engine wasn't connected up properly and was only intermidently working. hate buying second hand cars u never know whats been done to em
    My Ride:
    Previous rides:
