Results 1 to 7 of 7
Thread: why does the holden vs log book say that u use 20-50w oil
    Sep 2008
    Gold Coast
    Default why does the holden vs log book say that u use 20-50w oil
    why does the holden vs log book say that u use 20-50w oil and when u look up what type of oil to use from say castrol,shell supplier they say 10-40w oil
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    20W-50 is the way to go, if thats whats in the manufacturers book
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    20W-50 is Penrite HPR30.
    Wont hurt to use HPR 15 though, which is a 15W-50.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    that was the main viscosity available back then, now these days oils have gotten better and fully sythetics are mainstream as well, 10w 40 would be fine, i use 15w 50 mobil 1 or 10w 60 castrol both are fully synthetics to cover a wide range and good quality oil, just depends what you want to spend.
    VS Acclaim
    Nov 2007
    I use penrite 20w60 Gas even though my car isnt gas. The gas oil has the extra lubricant so it cant hurt to put it in petrol engines.
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    i used to work at a holden dealer and we used 20w 50 in anything older than VX as older engines need the thicker viscosity to prolong engine life
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Acclaim96 View Post
    I would guess that oil for gas cars has no detergent? since they run alot cleaner and don't wear out anyway (no fuel washing the oil away) so if that's the case they probably aren't the best ideal. I run diesel oil in mine now :P for the exact oppisite reason
  1. Red Book isn't free no more
    By MR_VX in forum General
    Last Post: 17-05-2009, 10:12 PM
  2. Does any one have his book
    By 88GreenVN in forum The Pub
    Last Post: 26-01-2007, 07:47 PM
  3. Monaro Book
    By Torana in forum General
    Last Post: 13-08-2005, 11:35 PM
  4. Map Book Holder
    By Ant in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2004, 03:42 PM
  5. Vl Book
    By SuperStar in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-04-2004, 05:29 PM
