Results 1 to 16 of 16
Thread: Speedo not working VS Statesman V8 5-speed
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Default Speedo not working VS Statesman V8 5-speed
    hey everyone. and before you tell me to do a ffs search i have done, and read all through the manual conversion thread. for VN-VR
    i've converted my VS Series II Statesman V8 to manual using a gearbox from a VN V8
    i need my speedo working. i'm using the auto engine loom and ECU, i know theres a way of doing this im just not sure what it is... ive got the reverse lights and neutral safety switch sorted. just need the speedo.
    cheers for any help.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    PM Morton on this site - he converted his VQ to 5 speed.
    and 3 Dangerous non ABS VN's
    Feb 2006
    Radelaide
    VN's use the 4L60 which have the same speedo plug as the T5, i had the 4L60E which is a different plug so i think im in a bit of a pickle..
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Like he said there, morton could use the auto computer without any problems. VS is where the problems happen.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Feb 2006
    Radelaide
    Quote Originally Posted by STEALTHY™ View Post
    i know, hence why i said the VS is different. thanks for the information i already knew...
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VRSS View Post
    I was replying to 88GreenVN, but you already knew that
    cheers sexy
    88GreenVN's Avatar
    Jun 2006
    Thanks Stealthy - gotcha
    Feb 2006
    Radelaide
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    hmm i got mine to work in my stato but not my senator....anyways...there should be 3 wires on the manual sensor...sense(purple/white), +(pink) and -(brown or black)..(i think thats the colours by memory). What you do it cut the plug of the sensor, run the sense wire up to behind the cluster and join it to the same colour wire that goes into the cluster, then go to the ecu and there should be 2 wires that are the same colour(purple with a white line) cut them...then pretty much run the + and - to a power suply...i used my cig lighter....then it should work...it worked on my vs but not on my vr so i guess you kind have to chance it...well good luck and hopefully that works.
    Feb 2006
    Radelaide
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its all in the manual conversion thread theres a violet wire in a plug by the ecu that goes to the dash join into that from the vss it will get the speedo working but the ecu wont see what speed you are doing as for power for the vss theres switched ignition power in the auto loom that used to plug into the auto that works great for powering the sensor
    Dec 2005
    Burpengary
    Feb 2006
    Radelaide
    oh fair enough.. that also means my trip computer won't work hey? hmmm any other way around it? speedo signal changers or something??
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    the trip computer will work fine.
    However you will have other running issues, although you willa llready be having them, my new VSS arrived today, it goes ina nd works like the regualr speed sensor, but it emits a puls (Same as the 4l60E VSS) so I am sending my memcal back to ejukated (A guy on these forums) for a tune to suit.
    Can't wait to have a perfectly running manual conversion.
  15. #15
    Dec 2005
    Burpengary
    mine runs totally fine, never had a issue with either one of my manual conversions...i just got foamy to tune my memcal to suit the conversion in my stato, but havent done my senator yet and still no issues
  16. #16
    Feb 2006
    Radelaide
    yeah mine runs fine too, just takes longer than it used to for the idle to drop
  1. Speedo not working
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2009, 06:12 PM
  2. VS Speedo Not Working
    By seraphic06 in forum Electrical Wiring / Questions
    Last Post: 30-03-2009, 11:26 AM
  3. speedo not working
    By clyde in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:07 PM
  4. km on speedo not working
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-07-2006, 01:01 PM
  5. Speedo not working
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 11:01 PM
