Results 1 to 13 of 13
Thread: VR Statesman....help
    VR Statesman 5.0
    Oct 2009
    Post VR Statesman....help
    Ok Had a problem with stalling when putting in to gear...everytime i put the car in to reverse or drive it would stall but would drive normal...put it in to the machanic they said it was the idle step motor they said they clean it and it was all good...no its not.....its doing the same thing BUT i can get it into gear but the revs drop low and sometimes stalls while driving please help as i have spent way tooo much money on this car....thank in advance
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    so it now jsut stalls in reverse instead of being in drive? BUT sometimes stalls when you drive along the street/road?
    At what speed does it stall when your driving along the street/road?
    dont worry, il start a ride thread soon.
    VR Statesman 5.0
    Oct 2009
    ok i can get it into every gear but idles very low and sometimes stalls and another thing when i go to start it i need to put a bit of throttle because it wont start by it self where as before they clean the idle step motor i didnt have a prob i know im not explaining it correct but thats the only way i can explain wats going on it just stalls everytime i go to put it in to drive or reverse and it sometimes stalls when driving it i can be going fast or slow it doesnt matter it just stalls as i said i have had it into 2 mechanics and they cant tell me shit
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    any dash lights on? after you get it into D and stop at say a set of lights does it still idle like crap? check your vacuum lines for any cracks or whistling noises, and also check the vacuum tank, its under the metal where the airbox sits, so you have to look up under the bumper/guard and you can see it.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    vr statesman 5.0
    Jan 2009
    i had a similar problem with my vr stato.have u done a code check?do that first.mine ran rough and kept stalling,problem was the map sensor,changed that and its perfect now.so do the code check man.do u know how to do that?
    VR Statesman 5.0
    Oct 2009
    FYI...its a dual fuel car if that helps at all ..and have no idea how to map it.... a mate said the same thing but dont know how...thanks
    VR Statesman 5.0
    Oct 2009
    as far as lights on the dash the oil light comes on just before it stalls
    vr statesman 5.0
    Jan 2009
    VR Statesman 5.0
    Oct 2009
    vr statesman 5.0
    Jan 2009
    Locate the diagnostic connector under the the steering column on the drivers side.
    Grab a paper clip and bridge pins number 5 & 6 'black' and 'white with black stripes' respectively on the ALDL (Assembly Line Diagnostic Link) connected which are located on the top row counting from the left.
    Jump into the drivers seat and turn the key twice (so lights are up on the instrument cluster).
    If you bridged out the correct wires 'Check Engine Lamp' will be flashing.
    The flashes are divided into 2 groups with roughly a second between each. You can read the flashes as follows:
    The first series of flashes is tens, so for example lets say the first flash simply flashes once, this means the code is 10. After the pause (~1 second) a second series of flashes will appear, if this number is 2, the code it is spitting out is 12 which means everything is fine.
    Another example just so you're sure
    The first series of flashes you count is 4 meaning 40, the second series of flashes is 3. Adding the 40 and the 3 will give you a code of 43 which means the Knock sensor circuit is experiencing problems.
    Each code the computer picks up is repeated three times with ~3 second pause between, so its wise to sit there to make sure there isn't any problems it has picked up.
    Once you are finished turn off your ignition and remove the paper clip. It is important to note not to drive the car around while have wires are bridged as this will prevent new codes from being logged.
    Any questions or queries please feel to contact me at anytime.
    Checking the computer for codes is used in conjunction with the computer Fault Codes located here
    __________________
    vr statesman 5.0
    Jan 2009
    there are the codes mate.hope that helps u find the problem.took me a bit to figure out how to do it but its not hard.
    V8
    Code 12 - System Pass (OK)
    Code 13 - Oxygen Sensor (O2) - No Signal
    Code 14 - ECT Sensor - Voltage Too Low - Auto Transmission Only
    Code 15 - ECT Sensor - Voltage Too High - Auto Transmission Only
    Code 16 - ECT Sensor - Voltage Unsteady
    Code 17 - PCM Error
    Code 19 - Throttle Position Sensor (TPS) Stuck
    Code 21 - Throttle Position Sensor (TPS) - Voltage Too High - Auto Transmission Only
    Code 22 - Throttle Position Sensor (TPS) - Voltage Too Low - Auto Transmission Only
    Code 23 - IAT - Voltage Too High
    Code 24 - Vehicle Speed Sensor (VSS) - Fault - Auto Transmission Only
    Code 25 - IAT - Voltage Too Low
    Code 26 - IAT - Voltage Unstable
    Code 28 - Pressure Switch Assembly Short Circuit - Auto Transmission Only
    Code 31 - Theft Deterrent Signal Missing
    Code 33 - Manifold Absolute Pressure Sensor (MAP) - Voltage Too High
    Code 34 - Manifold Absolute Pressure Sensor (MAP) - Voltage Too Low
    Code 35 - Idle Speed error
    Code 36 - Vacuum Leak
    Code 41 - Electronic Spark Timing Circuit (EST) Output Circuit Failure
    Code 42 - Ignition Bypass Circuit Fault
    Code 43 - Knock Sensor Circuit or Sensor Fault
    Code 44 - Oxygen Sensor Lean (O2)
    Code 45 - Oxygen Sensor Rich (O2)
    Code 46 - No Reference Signal While Cranking
    Code 47 - 18x Reference Signal Missing
    Code 48 - Crankshaft Reference Signal Missing
    Code 49 - Cam / Crank Shaft Signal Intermittent
    Code 51 - Memcal Unit (Commonly Known as PROM)
    Code 52 - System Voltage Too High - Auto Transmission Only
    Code 53 - System Voltage Too High - Auto Transmission Only
    Code 54 - System Voltage Unstable
    Code 55 - Analogue to Digital Error - Auto Transmission Only
    Code 56 - Running Lean Under Load
    Code 57 - Injector Voltage Monitor Fault
    Code 58 - Transmission Fluid Temperature - Low - Auto Transmission Only
    Code 59 - Transmission Fluid Temperature - High - Auto Transmission Only
    Code 66 - 3-2 Shift Control Solenoid Circuit Fault - Auto Transmission Only
    Code 67 - TCC ON-OFF Solenoid Control Circuit - Auto Transmission Only
    Code 68 - Transmission Component Slipping - Auto Transmission Only
    Code 69 - TCC Stuck ON - Auto Transmission Only
    Code 72 - Vehicle Speed Sensor Signal Intermittent While Driving
    Code 73 - Pressure Control Solenoid Current - Auto Transmission Only
    Code 75 - System Voltage Low - Auto Transmission Only
    Code 79 - Transmission Fluid Temperature - Too High - Auto Transmission Only
    Code 81 - 2-3 Shift Solenoid “B” Fault - Auto Transmission Only
    Code 82 - 1-2 Shift Solenoid “A” Fault - Auto Transmission Only
    Code 83 - TCC PWM Solenoid Fault - Auto Transmission Only
    vr statesman 5.0
    Jan 2009
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Maybe not him, but its just helped me out cheers for that.
    13 - got a dud oxy sensor New one comin up.
    Reaper
  1. vq statesman with vs statesman front
    By Mazzone_Child in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2012, 02:39 PM
  2. my 98 vs statesman
    By TheStateo in forum VR - VS
    Last Post: 01-03-2009, 10:12 PM
  3. VQ statesman
    By sxchsv in forum Car Audio
    Last Post: 24-02-2009, 11:58 PM
  4. My Vs Statesman
    By mjforever1 in forum VR - VS
    Last Post: 05-11-2008, 10:37 PM
  5. VS Statesman
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 09:11 AM
