Results 1 to 14 of 14
Thread: Frustrating Stalling Problem
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Default Frustrating Stalling Problem
    Okay I have looked up many threads and I have done what I can however I need some more help.
    For about a month my VS Ecotec has been randomly stalling - usually in the worst places imaginable. It is driving me nuts. To make matters worse, no codes are being logged.
    So far I have:
    changed the fuel pump
    changed the crank angle sensor
    cleaned the throttle body
    cleaned the idle air control valve
    changed the the idle air control valve (with a 2nd hand unit)
    changed the throttle position sensor (with a 2nd hand unit)
    cleaned the MAF
    cleaned the air filter
    changed the oil and filter
    spark plugs and leads have done about 17,000km (plugs have been cleaned in that time)
    changed the coils packs (with 2nd hand units)
    changed the DFI module (with a second hand unit)
    changed the oxygen sensors
    poured a bottle of injector cleaner into the fuel tank
    I am now running out of ideas as to what to do next. I thought I had solved it after replacing the CAS. For two weeks nothing happened - until today. I am wondering whether changing the ECU would do anything?
    It may or may not be related but the engine seems to be running rough at idle as well. While waiting at the lights the engine will usually "shudder" once. It's quite disconcerting. Under load though it seems to be fine. All this seems to have happened after I had a 2.5" cat back exhaust installed. Might that have caused something to go awry?
    Any ideas?
    98 vt s pac
    Feb 2009
    Corowa NSW
    hi mate i just had the exact same problem in my vs 5 mins ago i was sitting on 100kmph and then dropped down to 60kmph when i came to town then the engine cut out. I rolled to the side of the road and tried to start it again but nothing. waited 2 mins and bang she kicked over
    VRoooom!'s Avatar
    VRoooom! is offline Vroooom!
    VR Executive Series One
    Aug 2009
    yeh i used to have the same peroblem.
    turned out my brake booster was leaking and i had an engine vaccum leak.
    to much air intake.
    and my engine wasnt handling under load.
    so got spark plugs replaced etc etc..
    hope this has helped
    Vroooom!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Random stalling after all the things youve changed - I'd be inclinded to test a second ECU.
    I've done all the things you have stated above on my VN - and it was the ECU after 6 months of frustrating stalling.
    and 3 Dangerous non ABS VN's
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by 88GreenVN View Post
    Thanks for the advice everyone.
    Next question do I need a VS series ECU or are they all pretty much the same?
    Vs Calais
    Oct 2009
    Wodonga
    yep had same problem replaced ecu never had problem again i think all vs's ecu are the same but i ended up getting same year one from a calias same
    pervs's Avatar
    pervs is offline live life sideways
    vs commodore
    Feb 2009
    Default stalling problems on vs commodore
    iv changed the fuel pump, fuel filter,tps sensor, o2 sensor, air idle speed regulator, air flow meter, poured injector cleaner into the tank and always put bp ultimate into the tank and now everytime i put it into reverse or drive or stop at lights the car just stalls or the revs drop down to just above 0 and feels like its about to stall i dont know what else to try its driving me nuts iv spent so much money and getting no were
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Alternator or bad battery? My VR has stalled a few times while driving and it turned out to be a battery, since replacing it, have not stalled since.
    vs S3 ute
    Nov 2009
    toowoomba QLD
    yea you need a VS ecu, they're not compatible with others. vt MAY be but i doubt it.
    pervs's Avatar
    vs commodore
    Feb 2009
    nah wudnt be the battery or altinator coz their fairly new all electronics run fine just when i put the car into gear is when it struggles.. i was thinking it was the ecu aswel but cant understand how it would just cave like that
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    pervs's Avatar
    vs commodore
    Feb 2009
    how do i do that..iv tryed disconnecting the whole battery etc to reset the ecu but nothing im thinking just get a new ecu its prob my best bet..iv got a series 1 vs ecu but mines series 2 will it make a difference?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've scanned the page on resetting the base idle for the VS. It may or may not help but anything is worth trying. Good Luck.
    Attached Thumbnails Attached Thumbnails Frustrating Stalling Problem-baseidle.jpg
    pervs's Avatar
    vs commodore
    Feb 2009
    ill give it a go..thanks
  1. VR II stalling problem
    By Draught4me in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2009, 03:47 PM
  2. stalling problem with aftermacket s/c
    By plymouth_hemi_69 in forum V6 Development And Modification
    Last Post: 28-05-2009, 06:38 PM
  3. Stalling Problem VN
    By Raymond Packets in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2008, 11:33 AM
  4. s/c vt berlina problem stalling
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-09-2008, 10:34 AM
  5. Auto Vn Keeps Stalling... Frustrating!!!
    By saint_matrix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2006, 05:28 PM
