VEHICLE SPEED SENSOR?
how do i fix?
how much?
my car wont accelerate.
im at my wits end with this car.
Vroooom!
The VSS is located on the transmission (auto) so it doesn't look like it would be difficult to replace. Don't know the cost. DTC 72 means that the VSS has an intermittent fault so you get max line pressure and third gear only hence why your car won't accelerate.
thankyou for your response blackVXGTS.
yeh its like a plug ay.
similar to the oxygen sensor if im not mistaken.
so i can only use the gears?
i wanna try drive it up my drive way into my garage so i can fix it.
is this possible?
you will only have 2nd 3rd and reverse ide say slap the stick in 2nd and go for it unless the drive is real steap
thankyou delcowizzid.
would you have any idea how to fix?
is it like putting on an oxy sensor?
im still trying to gather as much as i can about this before i fix it.
undo the bolt and wiggle it out pretty easy.if the drive is steep and you dont want to strain 1st just reverse in will be nicest on the box in reverse
yeah thought so.
its kinda hard, cause my cars facing my garage but its like 30 metres away. the elevation to get there would be like 1 metre. shouldnt do any damage.
