Results 1 to 5 of 5
Thread: Urgent help Please vs wgn central locking
    Vr BT1 5lt
    Jul 2009
    Frankston
    Default Urgent help Please vs wgn central locking
    today i went to put a cd player in my car took the trim off around where the cd player should be and the bigger piece behind it, took the heater controls out checked the wiring for the cd player couldnt be bothered so i put it all back together and went to lock the door and it will not lock. check the fuse it is fine not sure if there is a relay for it???
    i dont think i have bumped any of the wiring??
    please help
    Thanks Mick
    Vr BT1 5lt
    Jul 2009
    Frankston
    Default re central colking
    just noticed my power windows are not working and the drivers door lock you cant push down to lock.when i press the button to lock it doesent seem to do anything but when i unlock the indicaters flash like normal
    Vr BT1 5lt
    Jul 2009
    Frankston
    Default re
    i just changed my body control module and it is still playing up????
    anybody any ideas please
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Did you change the BCM before it started playing up, and if so do you have the correct keyhead for the BCM? All the connectors for the power windows are under the CD player so I'd look there first.
    Does the red flashing immobiliser light go out when the unlock button on keyhead pressed?
    Vr BT1 5lt
    Jul 2009
    Frankston
    thanks for your help stupid me didnt check all the fuses problem solved
  1. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  2. VP Central Locking
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2008, 08:30 PM
  3. VR central locking URGENT expert help
    By Nebuchadnezzar in forum Electrical Wiring / Questions
    Last Post: 06-03-2006, 09:02 AM
  4. central locking again..
    By warney in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 12:21 AM
  5. Vs Ute Central Locking
    By nitro 55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2005, 02:16 AM
