Results 1 to 4 of 4
Thread: Shagged box
    VR Statesman
    Sep 2006
    Default Shagged box
    Hi guys,
    I've got a vr v6 auto ute that needs a new gearbox as far as i'm concerned but i'm just curious if anyone can shed any light on what's caused it to fail.
    the gearbox works fine cold but as it heats up the changes get a little longer until the box starts only working with two gears then possibly one. i wasn't really taking notice by that point. it also loses reverse but once it cools down it all works fine again.
    I gave it some from the lights after about five to ten minutes driving and it responded really well under heavy acceleration while cold. The computer picked up no faults in the twenty minutes or so i drove it for although the gearbox clearly wasn't having a good time.
    Any thoughts? I hate not knowing why it's stuffed.
    Fluid looks beautiful and levels fine
    ElDubya's Avatar
    ElDubya is offline Mad As A Meataxe
    1994 VR SS Sedan
    Jun 2005
    Give it a service. Mine was doing the same but after a filter change it works beautifully.
    The very existance of flamethrowers proves that sometime, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to do it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    VR Statesman
    Sep 2006
    Sorry to bring this back up but i thought i'd post in case someone else had the same issues.
    Finally dropped the pan on this trans and although the fluid didn't look too bad on the dipstick the fluid in the pan looked like motor oil as a result of fine metal sludge built up over years.
    The guy i bought it off didn't care much for servicing and i knew it because he is an old mate so it was no suprise that he hadn't changed the fluid or filter in the 3 or 4 years he'd been running this box.
    So i changed the fluid and filter and flushed the trans cooler and now it works like a dream i'd even say it changes a little better than my serviced box on my statesman. Of course i don't expect a long life out of it but at least it's working.
    My theory is the metal sludge was clogging the filter and once the box heated up the metal expanded and starved the pump of fluid.
    When i drove this thing before i wouldn't have believed the box could ever operate normally again but ElDubya was right.
    So if you have similar issues give it a crack and do it thouroughly, flushing is really easy.
  1. injectors more shagged than paris hilton
    By s0sage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2009, 11:06 AM
  2. auto shagged or normall?
    By s1knt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2009, 01:12 AM
  3. shagged clutch
    By immortality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2007, 10:23 AM
  4. wheels and tyres, 2 rwc, 2 shagged $350 only (bne)
    By warney in forum Parts And Other Items For Sale
    Last Post: 07-05-2006, 10:41 AM
  5. ignition barrel shagged?
    By don joe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2005, 12:26 PM
