Results 1 to 6 of 6
Thread: engine swap vs into vr
    vr wagon
    Oct 2009
    Default engine swap vs into vr
    any problems putting vs v6motor and box into vr,even complete front subframe as well
    the intakes are different and the pulleys and accessories in different places
    has any one done this
    what is involved and what parts are required
    i have complete vr wagon and vs sedan only missing the airbox
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    You will need to also swap the wiring and ecu.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    vr wagon
    Oct 2009
    all the engine wiring ? also would it be best to just leave motor and box etc on subframe to change over that way??
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    well you dont actually have to change the wiring and ecu, it might be easier to though.
    you can get an ecotec to run off of the buick ecu but it requires some modding.
    otherwise a fairly easy swap, remember with the ECU from the VS you will need the VS BCM and its wiring loom plus the keyhead.
    vr wagon
    Oct 2009
    have u done this change over ?
    is it possible to change over the inlet manifolds my vr is lpg and petrol
    woteva's Avatar
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by cee-1 View Post
    inlet manifold is different, it cannot be swapped.
    http://woteva.tk/
  1. vr engine swap into vs
    By melawramenko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2008, 08:08 PM
  2. engine swap v6 - v8
    By JB33 in forum General Discussion
    Last Post: 16-10-2008, 02:37 AM
  3. vr-vs v8 engine swap
    By little mick in forum V8 Development and Modification
    Last Post: 26-07-2008, 09:16 PM
  4. engine swap?
    By jazzawithvg38 in forum Straight 6 Development And Modification
    Last Post: 15-11-2007, 07:10 PM
  5. engine swap (vk to ??)
    By phat_com in forum Just Commodores Polls
    Last Post: 26-06-2006, 09:28 AM
