Results 1 to 18 of 18
Thread: vs commodore rough idle/vibration
    Ve Sv6
    Sep 2008
    Shepparton
    Post vs commodore rough idle/vibration
    Hi guys, just asking this question i have a vs commodore exc ecotec v6 and the engine seems to idle very roughly and has a bad vibration before you even put it in drive but once you take off and start moving its much better. Have been inspecting but so far no clue as to wat it is...cud it be balance wise? or something more major...thanks in advance
    VR Berlina S2
    Aug 2009
    having the same problem in a VR
    selling vp calais wheels with 97% rubber hardly used!
    Ve Sv6
    Sep 2008
    Shepparton
    yeah i ran the code check and got 76 which is air/fuel ratio variation between left and right banks????
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by LoudVTS2 View Post
    That could mean injector(s) blocked/dirty on one bank or plugs/leads misfiring on one bank or one of the coils dodgy for a start. Unfortunately tracing this type of problem means a process of elimination....I'd lean towards checking plugs and leads first, then the coils.
    Sep 2008
    Gold Coast
    i had alot of vibtation on my vs and it was the engine mounts that was no good once i replace them vibration was gone
    Ve Sv6
    Sep 2008
    Shepparton
    hmm engine mounts i did think of that...better go and check them out coz there is no miss in the engine at all just vibration so thats y plugs leads and injectors i dont think are the issue as there is no miss
    VS Berlina Wagon
    Apr 2009
    Hi,
    I'm having the same problem in my VS Berlina Wagon. How did you go with sorting out the vibration? Was it engine mounts?
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Quote Originally Posted by ant_1984 View Post
    Hi,
    Have a look at yours to eliminate the possibility, its easy, but you will have to get under it with a jack and bit of wood.
    vs commodore
    Oct 2009
    Tamworth NSW
    These engine mounts collapse before they actually break.With the collapsed ones its hard to tell if they are stuffed or not,you would have to measure where an engine sits in the engine bay when its fitted with new engine mounts then and compare the measurements to the engine sits in the engine bay with the old mounts ..My engine sat about an inch or more higher in the engine bay after replacing them.They helped big time to get rid of a bad vibration. .My car had a bad vibration,I replaced the engine mounts,gearbox mount,the centre bearing and uni joints and all the rear axle control arm bushes.It runs perfectly smooth now.If the actual engine itself is vibrating,(my vibration was from the middle of the car near the transmission), then check the harmonic balancer.If the plugs ,leads and coils show to be ok then the air/fuel variation between cylinders error code could also be caused a bad oxygen sensor on one side, or a vacuum leak on one side of the inlet manifold.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Brett_jjj View Post
    These engine mounts collapse before they actually break.With the collapsed ones its hard to tell if they are stuffed or not,you would have to measure where an engine sits in the engine bay when its fitted with new engine mounts then and compare the measurements to the engine sits in the engine bay with the old mounts ...
    or you could just jack the engine up with the car on stands, block of wood on sump, trolly jack under and jack up to see if the engine mounts separate. You should be able to see if there stuffed this way.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by bandit10 View Post
    Good idea.I couldnt believe how much higher my engine sat after fitting the new mounts.It made a big difference to how it drove too.A hell of a lot smoother.
    VX II Calais LS1
    Jan 2010
    yep, ive had this to.
    To look at them you would not tell anything is wrong, you will be really surprised with the difference when you fit new ones thought if they are stuffed.
    Apr 2009
    Attached is a picture of a stuffed one with no weight on it. You can see the gap in it that would probably make up for the squash before it failed.
    Attached Thumbnails Attached Thumbnails vs commodore rough idle/vibration-eng-mount-mediu-10.jpg
    VS Ute
    Apr 2010
    Default Stuffed Engine mounts
    Hi Guys
    I have 2 stuffed engine mounts and was wondering how hard it is to change them and what is involved in changing them
    Help would be greatly appreciated
  15. #15
    Apr 2009
    After lifting the weight off the mounts with a block of wood on sump and jack.
    I've only ever removed complete engines with mounts still attached.
    The 4 bottom nuts are easy, but the 2 upper nuts are harder to get too on the pass side if you have A/C. The pump has to be moved out of the way.
    Perhaps you can lift the engine enough once the bottom nuts are undone to make it easier to get to the pump.
    First and third image is pass side, you can see the upper nuts and 2nd is driver side,
    4th is wrong image, please ignore!
    Attached Thumbnails Attached Thumbnails vs commodore rough idle/vibration-p1010014-medium-.jpg   vs commodore rough idle/vibration-p1010012-medium-.jpg   vs commodore rough idle/vibration-p1010015-medium-.jpg   vs commodore rough idle/vibration-eng-mount-mediu-10.jpg
    Last edited by v6lux; 19-04-2010 at 07:30 PM. Reason: I "tarded" adding the images
  16. #16
    VS Ute
    Apr 2010
    VS S11 Clubsport
    Apr 2010
    Yeh mate sounds like engine mounts to me. Me and a mate tried changing engine mounts on my ride two weeks ago. Had an engine hoist to lift the engine just enough to do the swap, rear mount under gearbox and front passenger side weren't too hard but drivers side front mount was very hard to do. If i could turn back time i would have paid someone to do it for me
  18. #18
    VS Ute
    Apr 2010
    Hi
    what was hard about it . I was under the impresstion that passengers side was the bad one becauce of the air con pump
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. VP Commodore rough idle when running LPG
    By Boofe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2009, 03:31 AM
  3. Help VY II Vibration on Idle
    By jethro in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2007, 10:41 PM
  4. Idle Vibration
    By tommyboy84 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-10-2005, 08:36 PM
  5. VP - Rough idle, vibration and poor fuel economy
    By gospeedracer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2004, 11:35 PM
