Results 1 to 10 of 10
Thread: Help guys
    Commodore vs Wagon
    Jul 2009
    Exclamation Help guys
    Hey guys
    checked error codes and got 13 (oxy Sensor)
    My car has been rough lately so i want to no if this would be ok to put in it
    HOLDEN OXYGEN SENSOR FITS VS VT VU VX VY VZ OXY O2 - eBay Other Engines, Components, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 02-Nov-09 15:46:50 AEDST)
    do i need 1 or 2 of these?????
    Thanks guys
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    you need to check what yours is using now as vs models can have different sensors, some are 2 wire some 3 some 4 so you need to go check yours to see how many wires yours has first.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    v6 needs two, v8 needs one. If you did error codes it should have said left bank or right bank for a v6.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Commodore vs Wagon
    Jul 2009
    yes it said RH O2 sensor??
    i have a vs wagon series 2 so i can only see 1
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    Commodore vs Wagon
    Jul 2009
    so if i got 2 of those that are on ebay are they going to be ok to put in?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    you need to check how many wire yours are, being series 2 most likely 4 wire, but id still check
    Commodore vs Wagon
    Jul 2009
    do you no were i should look??
    i found the wire on the passenger side just cant see the other wire?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    If your sensors have never been replaced, then it is probably a good thing to do. Being a series II you will need the 4-wire sensor you linked to. However, don't be surprised if you still get a code 13 when you change them. I have had this problem of late, and it is caused by a poor wiring design. See:
    When does the car enter closed loop mode
    If you do have this problem see, suggested fixes:
    How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    Or:
    Ecotec development
  1. hey guys need some help
    By LoveB in forum Car Care Products
    Last Post: 29-10-2009, 06:38 PM
  2. sorry guys
    By shanghaivzcalais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2009, 11:47 PM
  3. thanks guys
    By hsv8vq in forum The Pub
    Last Post: 16-05-2009, 03:22 PM
  4. 253 or 308 sorry guys plz help
    By vks in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2007, 08:34 AM
  5. sorry guys
    By vp_s-pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2006, 10:36 AM
