Results 1 to 5 of 5
Thread: idle problems. won't sit at a constant idle.
    vt
    Oct 2008
    Default idle problems. won't sit at a constant idle.
    hey
    i just picked up a 93 mdl vr sedan, $500. had a manual conversion about a year ago. in allrite nic..
    the car will not sit at a constant idle. When i start the car it sits around 1500rpm, if i give it a slight rev it may stick at 2000rmp and slowly make its way back to 1500rpm.
    same situation but it might stick at around 1800rpm, then slowly make its way down.
    i added a return spring to snap back the throttle and im convinced that the cable is not sticking.
    what else could be causing the problem ?
    also the engine light on the dash is on. although the car runs beautfully besides the rough idle.
    thanks
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    VR should idle around 700-900rpm.
    Some things that it could be:
    IAC valve in throttle body stuffed.
    tight throttle cable
    bad earthing/loom
    im sure some other people will have some ideas
    If the engine is throwing codes, you should be checking them
    VS Executive 3.8 Eco
    Oct 2005
    ive got a leaky air intake caused from a terrible seal with the air intake piping that causes irregular rpm
    vt
    Oct 2008
    hey dude
    how do i check what error codes im getting ?
    im looking all over the forums buit i cant seem to find out how to check the codes ??
    thanks
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    You didn't think to look in the how-to section? There is a sticky thread right at the top
    Checking error codes VR/VS (Revised)
  1. vn, poor idle hunting and fan running constant!?!?!?
    By cracker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 12:09 AM
  2. idle problems
    By leigh 7005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2009, 12:22 PM
  3. Problems with idle...
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2008, 04:16 PM
  4. idle problems???
    By burkler in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-03-2008, 09:10 PM
  5. idle issues, 500rpm constant, thoughts????
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2006, 07:26 PM
