Results 1 to 6 of 6
Thread: VR idling issue
    VR Executive
    Oct 2009
    Default VR idling issue
    I am hoping someone can help.... this is similar to the other stalling queries but our VR commodore sedan (auto, aircon, cruise, 120k kMs) runs perfectly with normal fuel consumption, starts normally and normal performance. However, when we stop at lights the engine may sit at idle for any variable period and then sometimes miss a beat and recover. It istarted to appear about 6 months ago but is getting worse. Over the past 4 weeks the engine has actually stalled 2 times, but the car can be immediately restarted and all is fine. The problem only occurs when the engine has warmed up and the aircon makes no difference, as does sitting in neutral.
    I have replaced the HT leads but to no avail. I have also opened all of the engine electrical plugs and all are clean. I have spoken to an auto electrician who rattled off a stack of things that would be wrong and it all started to sound like he would be using the 'suck it and see' method. I was worried that I could be spending more on the repair than the car is worth.
    This is my first atempt at using this site and so I hope I have provided enough information.
    thank you
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    VR Executive
    Oct 2009
    Default I have the codes
    Thanks for the advice. I did the code check and only 2 codes are
    12 - OK
    47 - 18x Reference signal missing
    not sure what this means
    thanks
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Code 47 is your crank angle sensor - and makes sense with the problems you described, and is a fairly common problem
    It is located under the harmonic balance, and will need replacing. There are a few threads on how to do it yourself - see how you go.
    VR Executive
    Oct 2009
    Quote Originally Posted by aceventura View Post
    I have just spent a few hours on this site and love it! I have been looking in "http://forums.justcommodores.com.au/holden-commodore-how-tos/" but cannot find any reference to how tos for this. Am I off the track?
    thanks
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Yeah, not sure if there are any specific how-to threads, but there are plenty of threads on the topic - even another one today.
    Once you remove the harmonic balance, the job is easy. Do a search for harmonic balance removal, and that should get you going. In addition, a Gregory's or similar is worth the money, and it explains the procedure well.
  1. Idling issue VN S1
    By wagonist in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2009, 10:34 PM
  2. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  3. VS Exec - Idling Issue
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2007, 05:01 PM
  4. Help - Not Idling
    By Rachly in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-03-2007, 05:47 PM
  5. Low Idling
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-12-2005, 02:03 PM
