Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 159
Thread: Design for my air intake. Any good?
    VS Executive 3.8 Eco
    Oct 2005
    Default Design for my air intake. Any good?
    Well i finally ripped out my gas mixer because its a piece of it sh*t along with the converter that doesn't work, so i had to rebuild the intake. I ended up doing it like this. Just wondering if this set up is any good or if i should put it in a different orientation, and is there a way to make the ecu re-learn as i got a feeling its still set to a gas setup. Im gonna be getting a foamy tune done soon so its not too much of a necessity, mainly concerned for petrol consumption.
    on a different note do a bigger MAF make an large improvement on a N/A V6?
    thanks
    Attached Thumbnails Attached Thumbnails Design for my air intake. Any good?-imag0047.jpg
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    How is that secured, and where does it get cold air from?
    BXHD Guest
    why do people always get pod filters? dont they suck in hot air off the engine as well as some cold air? hmm. people told my bf to get a pod filter for his vl but i thought they were shit because u want cold air, not hot air...
    enlighten me people
    Oct 2005
    im getting a bracket for it tommorow to secure it down, and in terms of cold air... i do not know. the car had no airbox or original piping in when i got it, it had some terrible as gas set up. What do you recommend to do for the cold air?
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    You may aswell stick with your stock set up, if thats all you could come up with... back to the drawing board?
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Until you put that POD filter in an enclosure its going to be sucking warm/hot air form the engine bay.
    So doing more harm than good.
    Once you have an enclosure for it, should be all good in terms of functionality... though still not legal probably.
    Option 2 being to go to a wrecker, pull the airbox off a wreck and use that with a decent panel filter...
    Oct 2005
    i thought about mocking up my own induction system by running a pipe from the undercarriage up to the pod (which would then be in box)
    Aug 2008
    Quote Originally Posted by BXHD View Post
    enlighten me people
    A cold air intake system increases airflow by dropping the air coming into an engine to a lower temperature. Why is this important? As air gets colder, it gets denser. This means you get more oxygen within a smaller volume. More oxygen means more power. Increasing oxygen levels by this method can be found mostly in the racing industry. Many racers will dump ice on their intake manifolds and intercoolers to get a temporary increase in horsepower. Another aspect of a cold air intake system is reduced air flow resistance. All of the pipes in this system have been polished and tuned to reduce air flow resistance. This reduces unwanted turbulence within the pipes which would otherwise reduce airflow into the engine.
    I swear i didnt copy and paste that
    Oct 2005
    the original set up was the same but had the gas mixer on it and a pod with a hole in the side, i know its a terrible set up, trying to find ways of fixing it
    BXHD Guest
    Quote Originally Posted by HoldrodeoLT View Post
    LOL! niceee.
    Yeah i thought the cooler the better. if u have more hot air, lesser cold air is probably better im assuming. or even.
    schweettt
    Oct 2005
    whats the ideas of using a scoop to grab air from underneath the car, like a reversed OTRCAI?
    The Blues Mobile
    Dec 2008
    Western Sydney
    As long as you put something like a stocking (just as an example) over it so that non of that crap get into it like dirt and maybe water.
    *Note: Reversed OTRCAI = UTRCAI
    Vr Executive 3.8
    Dec 2008
    Just go to holden and buy the entire factory cold air induction set up.
    The scoop, connection to airbox, both halves of the air box, costs around 90$
  15. #15
    Oct 2005
    ok well im on holidays now so im gonna start mocking up my own UTRCAI (cheeborator im trademarking it now). Im going to be used those little scoops that are on the front of the VS bumper as my UTR scoops. Ill post pics and stuff when i get it all going. Just got back from clark rubber to get me some rubber.
    My plan is to bolt the scoops to the rubber guard under the bumper, then the rubber will wrap around the intakes and narrow off to a 3inch pipe. As there is 2 i will have 2 in 1 then one main pipe running up to a intake box. god i hope this all works. ill try and draw up a crappy paint drawing so you can visualize my dream.
  16. #16
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    if u get a encosure for it (mace) stopping the heat from getting in than ran a otr/cai would it b all good
    shhh now PUPPET
  17. #17
    The Blues Mobile
    Dec 2008
    Western Sydney
    Just don't drive over puddles during heavy rain, otherwise no air will get to the engine.
  18. #18
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i'd enclose the POD. a POD filter without shielding will suck hot air when the car is stationary. once moving there is enough air flowing through the engine bay, especially behind the headlight so it's no worse then the standard airbox
    Quote Originally Posted by Cheboorator View Post
    OTRCAI would be the best.
    Quote Originally Posted by Chris E View Post
    NOOOOOO. the Holden VS super6 (OTR)CAI is a heatsoak nightmare. especially when used in standard form. works ok once on the open road and all the heat has been sucked out but around town you may as well go back to the standard airbox and snorkel. i've got EFIlive data logs to prove all this too.
    won't be long before mine's for sale as i'm going the enclosed POD route on the VS just like i did on the VN
    Body by Holden, Soul by Brock
    the Legend will live forever
  19. #19
    Oct 2005
    my problem with OTR is that they are tried and tested that they work, now its time to find something new. anyway my art work is done hopefully this will give you some idea of what it will look like.
    the pipe will run op between the fan and the engine and then bend off to the box
    ill keep tabs on prices and stuff if this thing finally works for anyone else that might be interested
    edit: cheboorator i thought about that and im going to use foam inside the piping to stop any rain that may come from puddles
    Attached Thumbnails Attached Thumbnails Design for my air intake. Any good?-van-goughs-lost-art.jpg
  20. #20
    vs 5L ute and vh project
    Evel Cownievel Champion!
    Dec 2008
    NSW inverell
  21. #21
    Oct 2005
  22. #22
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by speed_freak View Post
    thanks
    How is it different to any other Pod system on the road??? You need to duct cold air from the front of the car somehow. HSV OTR system is as good as any.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  23. #23
    Dec 2008
    NSW inverell
    i bought the ute with the home made cai set up and bought the standard 1 for more air. But my the looks of it his cut the bottom out of the box and used expander foam then used car bog on top in the 1st pic u can c where is comin through the gard
  24. #24
    Oct 2005
    reaper theres two ways that can that it will be different from a typical OTRCAI. 1 is that the actual housing will not technically be under the bonnet. after a while the plastic from the OTRCAI has to heat up because of the heat from the engine, thus heating the air that comes through. Also the ducts from the OTRCAI are quite small and restricted where as the system that im going for will duct through more air.
    Anyway its just a new way of doing things, might be a cheaper and better option than an OTRCAI, or it might be a peice of crap. we will find out and see
  25. #25
    Oct 2005
    UPDATE NUMBER 1
    i mocked up how the vents will look. there will be two of them as i said before and then they will run into one single pipe and then straight into the air box. what do you all think
    Attached Thumbnails Attached Thumbnails Design for my air intake. Any good?-imag0048.jpg   Design for my air intake. Any good?-imag0049.jpg   Design for my air intake. Any good?-imag0050.jpg   Design for my air intake. Any good?-imag0051.jpg
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. AIR iNTAKE MOD (GOOD OR BAD?)
    By adz_vy in forum General
    Last Post: 29-10-2009, 03:18 PM
  3. VS Air Intake - Any good??
    By gigaz83 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 11:47 PM
  4. Rim Design??? help me out...
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 12:07 AM
  5. are these cold air intake kits any good??
    By stateo 304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2006, 04:17 PM
