Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: WILL VR HEADS FIT an ECOTEC????
    1995 VS Executive
    Mar 2009
    Default WILL VR HEADS FIT an ECOTEC????
    hey all begining a lil project car and just woundering if i would be able to retro fit some VR heads to the VS block ???
    any help would be great cheers boys
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    simple answer, no.
    advanced answer, yes with a custom inlet manifold and camshaft, but why bother, ecotec heads are much better than vr.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Why? The ecotec heads flow a lot better. They will bolt on but you will have to change a shit load of things.
    Visit my Facebook page
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by hakhawk View Post
    simple answer, no.
    I thought the 3800 and Ecotec head also had different water jackets?
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by _R_J_K_ View Post
    slightly different size holes from memory, just have to use the right gasket.
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    i also thought the exuast ports were differnt as well differnt in positioning
    VP Executive R-spec
    Jan 2005
    Yes the exahust and intake are different because the valves are in a different order but the heads bolt on read above ^
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    so who is going to be the first guy to bolt some ecotec heads on a buick with a custom manifold
    a buick with decent heads,results would be interesting to say the least
    Body by Holden, Soul by Brock
    the Legend will live forever
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by immortality View Post
    Wouldn't that then be an ecotec?.....just about....
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Not_An_Abba_Fan View Post
    not really, the ecotec is a evolution of the buick 3800, hence they call em series 2 3800 in the US
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    But the blocks are essentially the same, just the heads and intake were dramatically changed.
    hakhawk's Avatar
    Jan 2005
    blocks are rather different. one inch deck height difference for a start, which makes the distance between heads narrower. the ecotec block has extra bolt holes for brackets and such.
    i have pics of an ecotec head bolted to a vr block, was planning on making a ITB manifold, might still oneday, but ive been distracted with many other projects.
    if i can find them, i'll post them up
    Apr 2006
    Auckland NZ
    wish the earlier 3800's had the cross-bolted mains like the ecotec
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    My point is that the heads and manifold make it an ecotec, not the block. So by bolting the ecotec gear on the early block, in essence, it becomes an ecotec.
  15. #15
    Apr 2006
    Auckland NZ
    not really, the ecotec is the sum of all the parts that are changed. if you bolted the ecotec heads onto a earlier buick 3800 engine and then sat the ecotec intake manifold between the heads there would be a gap between the heads and the manifold. this is because of the 1" shorter deck height. therefor the pistons and rods are different also. not sure about the crank but i'd imagine thats different as well because the pistons have a much shorter pin height and therefor less mass so their must be less mass in the crank for ballancing reasons.
    if i remember correctly, ECOTEC is a acronym but i just can't remember what it stands for. the ecotec is infact a buick engine. the basic 90* V6 architecture didn't change. the heads flow much better and of course the new engine management and full sequencial injection
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Emissions Control Optimisation TEChnology
    By using the ecotec intake and heads, whichever block you use, would in effect make the engine an ecotec. Also using the ECU I suppose too.
  17. #17
    Apr 2006
    Auckland NZ
    you can ONLY use the heads. the intake manifold doesn't fit unless you cut it in half down the middle of the valley. and i'd run it with a 808/165 ecu and use MAP. much better then MAF
  18. #18
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    and ide say the rod to stroke ratio is a bit different unless its only the pistons changed to suit the lower deck height
  19. #19
    1995 VS Executive
    Mar 2009
    reason being,. have turbo manifolds for Buik engine and need to fit to dummy motor befor installing into engine bay have spare blown VS motor and wanted to use that .
    thanks heaps for the input
    also if any of you have some blown or shit VR heads you want to part ways with im interested in takeing them off of your hands
  20. #20
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if you build it all round a vs block with vr heads it wont fit the vr block and heads when you are finished
  21. #21
    1995 VS Executive
    Mar 2009
    ok no worries i'll just buy the buik now then thanks mate.
    once i get the project going i'll post up a thread and pics of the process .
  22. #22
    vp executive wagon
    Oct 2009
    A.C.T.
    just wondering dose any one know about aftermarket heads for buick and ecotec i have heard of abbot heads but can not find them help would be appreciated
  23. #23
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by dynoryder View Post
    Yella Terra probably do a set for each.
  24. #24
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    hmmm. so get a buick engine, add ecotec heads, drop custom inlet manifold ontop, and you can still run the ECU from the ecotec if you transfer the sensors i'm guessing.
    Sure it would work? wont it have issues using the ecotec ECU in regards to the CAS and other such things?
  25. #25
    hakhawk's Avatar
    Jan 2005
    keep going, custom camshaft to suit different lobe positions, and IEIEIE valve arrangement vs EIIEIE(or other way around, cant remember)
    lots of work, i was going to run a vr ecu, since i was going to have 6 throttlebodies and no plenum.
  1. Ecotec Heads S1 or S2
    By Col74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 01:42 PM
  2. heads for ECOTEC V6
    By Archers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2008, 04:16 PM
  3. ecotec heads
    By vt_on_20s in forum Parts And Other Items For Sale
    Last Post: 21-04-2008, 09:40 PM
  4. FS - Ecotec heads
    By muvro in forum Parts And Other Items For Sale
    Last Post: 22-10-2007, 05:57 PM
  5. vx ecotec heads on vr v6
    By race in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2005, 09:48 PM
