Results 1 to 18 of 18
Thread: Vs 1995 bonnet opening issue... not a car smart person
    Holden Commodore VS 1995
    Oct 2009
    Unhappy Vs 1995 bonnet opening issue... not a car smart person
    Hi There, I got a 1995 vs Commodore a few months back, its awesome,
    there is something up with the bonnet cable, the bonnet opens, but someone has to pull the lever while another person pushes on the front centre of the bonnet.
    I mentioned this to me friend who also has a commodore, and she said that its either the cable is too tight or too loose, but wasn't too sure..
    Please talk in not mechanic language as I'm a 20 year old girl that doesn't know much about cars, if you wanted me to change a fuse, i could do that, or put coolant in the car... done, but mechanical stuff no idea.
    is there an easy way to work it out and fix it, or am i best going to a car place.
    Thanks!!
    Mel
    VZ Calais
    Aug 2005
    Mackay Qld
    Hello Me.
    Try this.....reach in the door & pull the release cable.....slap down on the corner of the bonnet with your free hand [use your palm with an open hand, not a fist] .......tada! Bonnet pops.
    I had a VL with the same issues....& a torana.......& a VN.....lol
    If you open the bonnet, 'crack' the 4 bolts holding the bonnet to the hinge, then close the bonnet, next time you open the bonnet [when you check the water next] nip the bolts back up. It should cure the problem.
    Dont loosten the bolts, just 'crack' them. The virbation from driving around will 'centre' the bonnet & you wont have anymore issues.
    Well.....it works for me!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    An easy method (once you open the bonnet as above) is to loosen the single bonnet lock pin as per the pix/link - just undo it one turn.
    Attached Images Attached Images
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Another thing that happens is the clip that holds the bonnet shut bends where the cable attaches and it doesn't pull back far enough to release the pin.
    You will need two screw drivers, one to hold the clip in towards the edge of the hole, and the other to bend the end of the clip where the cable attaches. You have to bend it away from the direction of the way the cable pulls it. So bend it towards the passenger side.
    Visit my Facebook page
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Quote Originally Posted by hako View Post
    That picture you have contributated is what levels the bonnet with the guards.
    It doesnt have much to do with the level or anything...
    I hadf this problem...
    My mate said to lube the shit out of it...
    Then it wouldnt close.
    It may be the spring that holds the bonnet down.
    It may be too far centre which stops it from opening correctly.
    Try to peel back plastic thats under the radiator.
    The plastic is closest to you.
    Under there there should be the cable and a bit of the spring.
    Hold the spring in place with a flat head screw driver then get another screw driver, put it in the hole where the spring holds the bonnet and try to bend it towards your left.
    Oct 2009
    Quote Originally Posted by coolngroovy View Post
    Where would I find these bolts?? is it up near the top left corner (near the drivers door) do you have a photo at all??
    The spring way seems a bit complicated for me.( thanks though). though if i had some photos of the sections it may make more sense, if not i'll have to get a mechanic to fix it!
    Thanks for all you help!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    defs give this a go i had the same problem turned it a little bit and it workd perfect now
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    VP Exec
    Jun 2005
    The cable can be adjusted too. With the bonnet open, lift the plastic cover strip between the radiator and the car body, and trace the cable back towards the driver's side of the car about 200-250mm. You will see a tiny metal clip that holds the bonnet cable to the car body. If you loosen the bolt that holds that clip in place, you can pull the cable away from the bonnet catch to take up any free play, then retighten the bolt to hold it.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Hello Me.
    amen I thought that was standard procedure for opening commodore bonnets?
    94 VR Executive
    May 2009
    Windermere Park, NSW
    This worked for me when I got my VR.
    Homer28b
    94 VR Exec
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    coolngroovy i'm going to try that method simply to center my bonnet, I can never get it perfect, my bonnet opens fine but this thread was a big help cheers.
    Oct 2009
    My auto electrician put some grease on the spring and nob thing and it seems to open now, what a nice auto electrician! Seeing as i didn't even take it there for him to fix, he did a couple other things too, and he didn't charge heaps woot!
    Thanks guys!
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    just be carefull this method can bring on the other dreaded commodore bonnet issue smashed windscreens from the bonnet opening into the screen that sucks real bad i tell you
  15. #15
    Vs v6 commodore
    Nov 2009
    Post help??
    hey guys
    i have the same problem with my vs commodore the bonnet wont open at all now even when we press in the middle of the bonnet and pull the leaver we even tried everything that is mentioned on here but it still wont open got any ideas??
  16. #16
    VR Executive
    Aug 2011
    Coolngroovey,
    I was skeptical when I heard this advice [use your palm with an open hand, not a fist]
    Sounded like Fonzie hitting the jukebox.......
    I worked a treat. Thankyou guru of the bonnet release!
  17. #17
    VS Series 2 Wagon
    Jul 2011
    Australia
    just turn the the thing that looks like a spring maybe 1/2-1 full turn. I did it worked fine now for 6 months. They can just get a bit loose sometimes...
  18. #18
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Or if all this seems to hard for you then you could just leave it? Lol if its not causing a major problem just leave it.
    Just make sure when you wana check your oil and water that someone can give you a hand opening the bonnet.
  1. ban this person
    By rob drag racer in forum Site Feedback / Site Problems
    Last Post: 13-06-2009, 03:06 PM
  2. boot opening issue
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2008, 10:16 AM
  3. bonnet cable issue
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2007, 10:31 AM
  4. Opening VS bonnet - help
    By ernist_pagnito in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 08:59 PM
  5. petrol cap cover opening / bonnet opening
    By Rev_neil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2005, 02:13 PM
Tags for this Thread
