Results 1 to 25 of 25
Thread: ebay - sway bar link pin
    2000 VT BERLINA LS1 by design
    Oct 2009
    Default ebay - sway bar link pin
    just wondering if anyone has purchased a heavy duty sway bar link kit off ebay???
    they sellin them for like $15. probably shit but just after a comment or too in regards to them.
    Current Ride: VRll 5Spd Poverty Pack
    Previous Rides: 99 VT2 Super 6. (too much too list. was off its head$$$$$$$$)
    VS S Pack
    Sep 2009
    not sure about the one you are talking about but I have one of these sets
    COMMODORE HEAVY DUTY SWAY BAR LINK KIT VN VP VR VS VT - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 31-Oct-09 11:38:19 AEDST)
    Cost a little bit more but man what an improvement this made to the car - mind you the original link pins were shot
    Chris
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I bought one, but turned out it didn't fit my aftermarket sway bar, so I sold it to someone else
    It looked the goods though, I wish it had fit. It's really just a metal rod, some washers and a couple of bushes, which is why they can sell them for ~$30.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Oct 2009
    ok sweet, i might look into gettin one, gotta do the lot to try and stiffen her up a bit more
    VY Berlina V6 / R31 Skyline
    Dec 2008
    not sure about the no name brand ones mate, do you have a link?
    i have the White Line heavy duty link pins and polyurethane bushes and they are great, but were $50
    danja's Avatar
    Jan 2006
    The biggest advantage with poly bushes is they are tougher. I was going thought rubber link bushes every few months because the factory link pins were a crap design in the VT, and still not brilliant up till the VZ when they finally put ball joins on both ends.
    Dec 2008
    i agree there mate, though white line and few other companies have made an aftermarket ball joint for both ends of the sway bar eliminating link pins, allowing you to have the same mechanism as on the VZ
    danja's Avatar
    Jan 2006
    Quote Originally Posted by sweefu View Post
    If I remember rightly, the Whiteline sway bar I had in the front had a lower ball join, you'd need to get a VZ strut for a ball join on the other end.
    Can't see why it wouldn't be possible to do a conversion.
    terry0400-40's Avatar
    terry0400-40 is offline I AM. Out of my mind ....
    VS Executive
    Sep 2009
    Ihave also purchased a set of pins and bushes from eBay for my VS.
    http://cgi.ebay.com.au/Holden-VN-VP-VR-VS-VT-heavy-duty-sway-bar-link-bush_W0QQitemZ250520542892QQcmdZViewItemQQptZAU_Ca r_Parts_Accessories?hash=item3a54301eac
    I AM. Out of my mind .... .... ....
    VS Executive
    Sep 2009
    Quote Originally Posted by Trikky View Post
    Chris
    Also a Nolathane kit available from the same eBay seller as above mentioned, at a reasonable price i notice when compared to some other sellers of the exact same kit..
    Nolathane Sway Bar Link Kit
    Sway Bar Link Replacement Kit
    To Suit
    Holden Commodore
    VN,VP,VQ,VG 8/88 to 7/93 6/8 cyl
    VR,VS 7/93 to 9/97 6/8 cyl
    VT & VX Series 1 9/97-
    Attached Thumbnails Attached Thumbnails ebay - sway bar link pin-nolathane-sway-bar-kit-bushes.jpg
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    I had one of the z bar kits on my vs and did end up pulling the bushes off of one sid on the bottom only as is common. It wasnt as bad as the original bars and does help. I have recently switched to ball joint top and bottom link bars and that should give the movement that will help it out once and for all.
    VR WAGON
    Oct 2009
    Got a set myself of Ebay, lowered my car, followed the fitting ins. on "ebay" no probs at all. Don't reckon they do much from standard,but gotta be better than worn out old ****ers, that are 15 yrs old! Your not on a race track and if you were THEY DON'T MAKE A DIFFERENCE to the handling........ in the head ya know!!!!!
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    Heavy duty links aren't really needed unless you have an aftermarket sway bar. I have the 30mm whiteline sway bar and kept the old links on, and in a day, the bottom bush on the link broke off (lots of rattling), the old links were also bent at the bottom at almost 45 degrees, so they were uselss. The heavy duty ones off ebay are all the same, the only difference in costs is the quality and type of bushes used. Buy a cheap link kit, and most likely the bushes will break off within a month. The nolathane ones are pretty reliable, the bushes will last ages. As for the links themselves, they are all the same, and pretty thick, so they all do the same thing.
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by sly_gen3 View Post
    so i guess a turbo locks both back wheels together? or is that a supercharger? thats what my cousin told me. Who also happens too be my girlfriend. She has 2 heads aswell.
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    i have just ordered a set of of ebay, i was dirving round yesterday, and i snapped a link pin ,
  15. #15
    VS Executive
    Sep 2009
    Quote Originally Posted by VN-Commonwhore View Post
    Yes i also fitted a new set yesterday as i was getting a little clunking sound from the front end , the new set has stopped the clunk caused by the original old pins and worn bushes and my girl is cornering as smooth, quiet and tight as new.
    Attached Thumbnails Attached Thumbnails ebay - sway bar link pin-sway-bar-link-bushes.jpg
  16. #16
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Wink
    Quote Originally Posted by terry0400-40 View Post
    ill take a picture of mine from my VN, still originals lol, the bushers are F****D haha, cant wait till mine get here, be alot better of a ride :P
  17. #17
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
  18. #18
    VS Acclaim S1
    Nov 2008
    my link pin ahaha
    wait, is your pin broken? haha. your bushes look in better condition than mine and i put mine on 4 days ago!
  19. #19
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Quote Originally Posted by jashdown91 View Post
    mine is rooted hahaha, it snapped rofl
  20. #20
    VS Acclaim S1
    Nov 2008
    hahaha wow. ive never known the original links to break from the use of a standard sway bar. thats intense. you been driving it like ken block or something?
  21. #21
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    i have no idea, i was sitting on bout 70, then this metal rattling started, pulled over, sand saw it, not to happy lol
  22. #22
    VS Acclaim S1
    Nov 2008
    damn, thats unlucky. mine bent and the bush broke off and rattled. thats how i found out. so i bought a heavy duty link kit. so much better. but now its knocking when i go over speed bumps slowly, but all the bushes are there, cant find what the noise is.
  23. #23
    vx
    Nov 2009
    hi
    in the picture vn-commonwhore added
    is the bottom bar the Z bar?
    also why are the VX sway bar diff tent to the VT?
    VX got a ball joint on the bottom of the sway bar not bushes.....
  24. #24
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    The Z-shaped sway bars are rubbish if you have a lowered car. Ive got ultra low kings in the front, and I snapped 3 pins, where the thread starts. Each in less that a couple of weeks.
    Best thing to do is go to Bursons and get the standard link pin kits they sell. With the straight pin, not Z-shaped.
    They are only abouy 40-50 for the pair including bushes and everything you need.
    Finally replaced the Z-shaped pins with the aftermarket copys of the originals from Bursons, been in for 6 months, havent had one problem.
  25. #25
    Dan VS 231's Avatar
    VY Calais L67
    Jun 2008
    Perth W.A.
    This is the kind of link pin I was talking about a few posts up.
    VN-VY Heavy Duty Link Rods – WA Suspensions - Osborne Park, Perth, Western Australia – Suspension Parts & Servicing
    They are holding together well so far and I have not had an issue with them at all.
    (I didnt actually get them from those guys but they shouldnt be hard to find.)
  1. help me with sway bar link pin
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2011, 04:57 PM
  2. sway bar link kit
    By tug33r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2006, 10:27 PM
  3. Sway Bar Link
    By zuluchief in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 09:28 PM
  4. Sway Bar Link Mod
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 07:14 PM
  5. VN sway bar link kit??
    By stockVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 03:04 PM
