Results 1 to 2 of 2
Thread: coolant line going into timing cover
    VN
    Mar 2009
    Default coolant line going into timing cover
    Had to get a new timing cover as i cracked my old one trying to put it back on
    The new one didnt come with the metal pipe for coolant that the heater hose goes into.
    I had a hell of a time getting the old one off the old timing cover... however it doesnt appear to be a thread or anything, it just sits in there.
    I replaced the o-ring and put it in the new timing cover... however it just wobbles, feels loose. In the old one it was tight
    is there something else that needs doing? some sealant or somethin?
    Ryan
    VP Exec
    Jun 2005
    On a VN series I it does just sit in there, retained in position by the nut on the bracket under the power steering pump. The old one will have been tight because of corrosion.
    It's possible that on an old cover with some corrosion that you may have to use some silicon based sealant, even with a new 'O' ring, but they are not designed to need that.
    Some rubber grease may help the 'O' ring slide in.
  1. VZ sv6 Timing Cover
    By guyrussell in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-06-2008, 11:33 AM
  2. coolant leaking timing cover temporary fix???
    By NOGEN 3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2008, 12:36 PM
  3. Timing cover
    By furion in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2007, 03:54 PM
  4. timing cover
    By callum87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 07:52 PM
  5. timing cover
    By dave671 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:09 PM
