What's wrong.
My horn only works when the steering wheel is turned.
What I've done.
If taken the center of the steering wheel off, checked the wires, cleaned the copper plate and it still only works when i turn the steering wheel.
Anyone got any suggestions? i tried searching in the howto section but all i could find was guides for how to change a horn or guide on horns that dont work.
Thanks for the help guys.
yeah i thought it might be a common issue but i cant find any answers.
anyone able to shed any light on this issue?
by what your saying your car has no air bags with means its got a horn slip ring and contact brush. youll have to replace the brush cause it will be worn out. or you can go for the easy solution and build it up with some solder.
lol i have the opposite problem my horn only works when its straight
whats the difference between my missus and my blower??
well they both whine but the blower actually puts out
its most probably the contact pin above the steering wheel. They wear down after a while and the copper ring on the steering wheel isn't completely flat so therefore it can only make contact at the sides. You can just whack another contact pin in or do like i did to get me through and put a fired .22 shell over it lol
