Results 1 to 6 of 6
Thread: Holden Vs temperature gauge Problem
    2010 Holden VE SIDI SV6
    May 2009
    Default Holden Vs temperature gauge Problem
    G-day All,
    everytime i stop my car the temperature gauge goes past half way is this a problem or is meant to be... dont really want to buy a new engine :S
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I guess you mean when you are driving and stop at lights or whatever with the engine still running that the temp gauge goes up to 1/2 or higher - if this is what's happening it's completely normal. The Commo has an electric radiator cooling fan which only turns on when the gauge reaches about 3/4 or the A/C is tuened on. When the car is in motion, ram air is sufficient to cool the radiator.
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    FFS
    ok now I got that out of the way... It's normal mate, when your stopped there isn't enough airflow getting into the car/engine, especially when your in traffic and all the hot exhaust fumes are getting sucked in. When your moving, air is moving into the front of the car, therefore keeping it cooler. Also, the thermo fan will kick in at some stage just after halfway and it will cool. Also make sure you have water in the radiator/overflow, I know too many people that ask this question and they don't even bother checking that there is no water in the frigging radiator and overflow.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VR SENATOR
    Oct 2009
    I have a Vr senator. I have replaced the radiator and thermostat. My car sits at around half way but will get up to 3/4 when im in traffic. You guys say its normal. Does anyone know what temperature 3/4 is? I dont want to have any problems escecially with summer coming up
    I use to own a VZ maloo and i never remember my gauge going past half way..
    cheers
    Vs Equip
    Jul 2008
    OK with the vr-vs commodore it goes up to 3/4 with air-con off is normal with the newer commodores it only goes to half way. So vs 3/4 normal vt on i think half way got it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The cut-in temp for the VS cooling fan is 104deg C for low speed (3/4 on gauge) and 109deg C for high speed (7/8 gauge) Both will cut-out when temps are 5 deg C lower. Turning the A/C on will put fan to HIGH irrespective of gauge reading.
    From the above it's clear that the VS is designed to run HOT.
  1. VT Temperature Gauge
    By brett_b in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-03-2010, 09:50 AM
  2. Temperature Gauge
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 07:49 PM
  3. temperature gauge
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 09:59 PM
  4. Temperature Gauge
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-12-2006, 10:12 PM
  5. Vt Temperature Gauge
    By stephen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2006, 10:18 PM
