Results 1 to 7 of 7
Thread: VS Gear change timings
    VS Executive II v6 3.8L
    Oct 2009
    Exclamation VS Gear change timings
    You will have to forgive me im a complete newbie with cars, my problem is I just bought an Auto VS V6 and the gear change timings seem very weird. When i am in economical mode and i put my foot right to the floor it revs very high before changing gears however if i take my foot of the accelerator at about 2500-3000 revs it changes just fine as if im pushing the engine to hard for it to change. When in power mode this happens far less (the gears appear to change far more aggressively) but it still sometimes does the same thing and just generally feels like the gear box is all over the place but its almost always smooth with maybe a slight jolt moving from 1-2 but nothing that seems unusual. I have driven a number of FORD automatics and have never seen this lag in timings is this just a HOLDEN thing? I recently had it serviced and a lot of work done and he made no comment on this at all (forgot to ask). If this is normal would a performance ECU make things better? Seems there is a lot of stage/level four's (whatever that means) going for about $100.
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    you need to fulsh the fluid and change the filter this will fix it
    my gearbox nearly snaps your head off it has had two filters the first fixed it now i need the a new gearbox i cooked it
    VT spac super6
    Nov 2008
    Riverton sa
    your trying to get the most pick up as possible by holding your foot flat obviously.. so the trans will hold its gear alot longer than usual to use all possible power.. its ment to be like that and every automatic acts the same..
    shift points are set on the computer, if you dont like it revving out so far.. get your foot out of it its simple lol
    stage "4" is basically a fully manualised box, will go into any gear any time and you have to select each gear manually..
    stage 2 is the most common as it eliminates slip between gears feeling alot sharping and crisper changing, so much so in some fit ments the car will "chirp" into 2nd gear
    vp executive wagon
    Oct 2009
    A.C.T.
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by waffles666 View Post
    he said its always smooth
    vp executive wagon
    Oct 2009
    A.C.T.
    Quote Originally Posted by HARVZ-6 View Post
    yea i must of exagerated the jolt in my head
    Oct 2009
    Default Cheers
    Cheers for the quick replies the mechanic did say it needed a flush so its good to hear that, seems like a simple fix and looks like im not looking for a stage four i can't think of anything more annoying then having to change gears manually with the auto setup so i might pickup a stage 2 there going very cheap on ebay and the like.
    Can't say iv seen this helpful a community on the web for quite some time
LinkBacks (?)
  1. 30-10-2009, 07:28 PM
  1. Gear Change Auto
    By ufo8mycow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2009, 11:28 PM
  2. VN-VS - Change gear selector LED
    By Infus10n in forum Holden Commodore How-To's
    Last Post: 29-11-2008, 12:05 PM
  3. Automatic gear change
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-11-2008, 07:33 AM
  4. seems like timings out
    By ghostmobile in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-01-2006, 10:18 PM
  5. Rough gear change
    By veclubby in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 10:15 AM
Tags for this Thread
