Results 1 to 17 of 17
Thread: VS Ecotec Heat Shields
    VSSECO is offline Underdog rebuild
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Default VS Ecotec Heat Shields
    *** FOR SALE ***
    4.2L Buick V6 Billet Stroker - Built for big boost
    HUGE $$$$ SPENT - Selling well under half of the build cost
    http://cgi.ebay.com.au/ws/eBayISAPI....STRK:MESELX:IT
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    In theory they should work and I dont see why they shouldnt. Just make sure to protect your plug leads with some kind of insulation on the edges of the shield as they can and will slice the leads which will cause issues as you could understand.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My opinion only but I cannot see how they would be of much help - the air intake, whether CAI or standard sits well in front of the exhaust headers away from this source of heat - in traffic the temp of your intake air and it's relationship to performance doesn't matter as you are only crawling along.
    When cruising the ram effect flows the heat from the headers under and to the rear of the car. The ECU monitors the intake air temperature and adjusts the fuel/air mix to suit.
    You could probably obtain a similar benefit by wrapping the air intake with aluminium foil.
    However, I must admit they would look pretty smart on an engine.
    Vp series 2
    Jun 2008
    it would reduce the convection effect of hot air rising a little.
    So may help to keep the bits up top a little cooler.
    I'm considering making something similar but ashit load bigger.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Marketing. That is all.
    My opinion is that they may stop a bit of heat but won't make any difference to performance.
    Visit my Facebook page
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    only really worthwile on the passanger side to stop radiated heat from heating the intake duct. i have this on both my cars. i've also wrapped the intake pipe on the VN with header wrap. i can make em for about $20 worth of ali and couple hrs time to cut and make em.
    FIT was the first to make heat shield in this fashion, although i believe i was the first to cut holes for the sprakplug leads. all the previous designs have notches cut in from the top for the leads. looks remarkably like mine really
    they can be made to fit any ecotec or buick with slight alterations
    Body by Holden, Soul by Brock
    the Legend will live forever
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i was just thinking they look just like your drawings i have that you posted on here mate LOL
    Apr 2006
    Auckland NZ
    Quote Originally Posted by delcowizzid View Post
    sure does, even the hole for the last sparkplug lead is slightly closer even though the sparkplug spacing is the same. they just haven't put the first bend in along the top ofthe holes forthe spark plug leads like i did
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    noticed they made out of stainless steel, just another heat soaking device in the engine bay if you ask me, they would need to be made out of 2 different materials separate with some sort of air gap between the 2 materials for it to work efficiently, Ya know like the ones on early Japanese cars, one piece folded over the other.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Apr 2006
    Auckland NZ
    polish em, underneath as well, then it actually reflects the radiated heat. as hako mentioned, once your moving airflow through the engine bay will keep things reasonably cool. it's more for those periods that your idling, it helps to keep things a bit cooler, stops the intake duct from getting heated by all that radiated heat that comes of the headers. the best solution is to actually get your headers coated but this is a lot cheaper
    on my VN my entire intake tract stays cool, even the TB is only slightly warm which is much better then the standard setup which can get quiet warm. by itself it might not make much difference but with all the other mods it does add up
    also run a cooler thermostat and alter the on/off settings for the thermo fan in the tune, keeps things much cooler
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Yeah I reckon the passenger side would be the only side that would do anything. But it would probably look cool having both sides I guess, might make the engine look fatter with both. I still dunno though. Might just try to wrap up my intake pipe like you Immortality, I reckon that'll do the trick
    *** FOR SALE ***
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Before I bought my Commodore I owned a few Jaguar XJ6's with twin SU carbies - anyway, they were fitted with a "fuel cooler" which was a device that used the refrigerant from the airconditioning to cool the fuel before it entered the fuel bowls. It would reduce the temperature of the fuel down to about 3 degrees C. But even with this the old Jags loved to boil coolant, brake fluid, engine oil and petrol usually all at the one time.
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by hako View Post
    LOL @ Jug Jag
    N/A
    Apr 2009
    VIC
    ye i got these in my car. Work very well. Stops a lot of the heat inside the engine bay. The intake pipe hardly ever gets hot or just gets warm. I would recommend them to everyone with a VS trying to keep it cooler.
  15. #15
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    i have seen these on a website somewhere but cant remember what it was, anyone know?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  16. #16
    N/A
    Apr 2009
    VIC
  17. #17
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    cheers for that dude ^
  1. [NSW] For Sale: VS-VY Ecotec FIT stainless Heat Shields
    By chevy_big_block_bro in forum Parts And Other Items For Sale
    Last Post: 30-03-2009, 10:32 PM
  2. F.S. F.I.T. ecotec cool pack (heat shields/81C thermo etc)
    By xlr8_87 in forum Parts And Other Items For Sale
    Last Post: 06-07-2008, 11:11 AM
  3. Heat Shields
    By CRJ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-10-2005, 10:28 PM
  4. heat shields
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2005, 02:17 PM
