Results 1 to 21 of 21
Thread: ready to torch my car
    VN
    Mar 2009
    Default ready to torch my car
    hey
    i removed my timing cover, removed the timing chain/sprocket, removed the sprocket that drives the balance shaft, replaced the chain/sprocket, and put it all back together.
    Car was cranking over fine but wouldnt start due to a faulty CAS (couldnt get the stupid thing on properly with the plastic thing that holds it, so i ditched that and just bolted in the cas)
    Now when i turn the engine by hand, it turns until it gets to a certain point... then it refuses to go any further. Almost like it's hitting something
    Likewise if i turn it the other way... turns until it gets to that same point, and wont budge.
    Wont even budge with the starter.
    What could this be?
    VR Executive S2
    Jul 2009
    Victor Harbor SA
    VN
    Mar 2009
    VY S Sedan
    Sep 2007
    Sounds like you've got the valve timing out of whack and a valves hitting a piston.
    vr
    Jun 2009
    if the timing is not right, and you have been trying to turn it over with the starter,there is a good chance that a valve or 2 is hitting the piston and more than likely you now have a bent valve. take the timing cover back off and double check that the cam timing is spot on. and another nother note..only turn the engine in the correct direction of rotation.
    VN
    Mar 2009
    everything sounded okay before... i dont know how this could of happened
    i give up, anyone want this car?
    vr
    Jun 2009
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    which cog did you take off the little one on the balance shaft itself
    VN
    Mar 2009
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    is this any help?
    Attached Thumbnails Attached Thumbnails ready to torch my car-timming-marks.jpg
    and 3 Dangerous non ABS VN's
    VN
    Mar 2009
    well the torching is on hold just for a minute, i took the timing cover off and the engine turns over fine...
    so i have no idea now
    VN
    Mar 2009
    put it back together, started it up and its making a horrible rattling noise.
    on top of this my sump is full of water.
    i guess it could be the timing cover leaking. i dunno, i give up. If my engine's not completely rooted, i'll pay someone to fix it i guess
    VSSECO is offline Underdog rebuild
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    When you took the timing case off again, did the marks in the timing gears line up? It sounds as though you've put the gears on without lining them up and have damaged some valves
    If so its gonna be an expensive fix... Someone will have to remove the heads and reco them, new valves and maybe guides if they're damaged too then some new head gaskets and put it back together. Last time I priced it, it was about $600 for a head reco job but thats if you remove the heads yourself etc. Probably a similar price to do an engine swap these days.
    How did you get water in your sump? Didn't you drain the fluids before taking the timing case off?
    *** FOR SALE ***
    4.2L Buick V6 Billet Stroker - Built for big boost
    HUGE $$$$ SPENT - Selling well under half of the build cost
    http://cgi.ebay.com.au/ws/eBayISAPI....STRK:MESELX:IT
    VN
    Mar 2009
    yeah they lined up... everything was fine. I turned the engine by hand, and also just with the starter, everything sounded fine.
    I'm wondering if the wrecker i got the timing cover from has given me the wrong one... which may explain why water is going straight into the sump, and perhaps its not getting oil which would explain the rattling i can hear.
    Are there differences in the timing covers? It certainly look the same from the outside, and bolted up the same.
  15. #15
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
  16. #16
    VN
    Mar 2009
  17. #17
    Set of thongs
    Dec 2005
    Stonedville
    could be wrong timing cover and wrong gasket, folowed by timing. its a pre ecotech yes? did the gasket look right and the timing cover to, its always better to compare. vs timing cover looks the same but is different with the oil jackets. sumtime its easier to take the old timing cover in to an ally roo bar place and get them to weld it. about 30 dollars.
  18. #18
    VN
    Mar 2009
    ok took the timing cover off again and compared the two... they look the same. It musnt be sealing properly i guess. There's 2 bolts that i broke... thought i'd get away with it but obviously not.
    One is the bottom one that holds the CAS... broken flush with the block, can't get it out at all. So i got someone to put a heli coil in the timing cover so i could screw the CAS in.
    The other one , the thread is stuffed and its near the coolant line, i guess this may be the culprit. I dunno
    anyways mate if your still keen on fixing it for me let me know!! I've had enough!
  19. #19
    Set of thongs
    Dec 2005
    Stonedville
    Quote Originally Posted by ryan1980 View Post
    those bolts need to come out i have spare bolts here. they are in the spots as it needs to be there . do u have msn? i should be able to get the bolts out and possibly fix the thread in the block . i will have a look tomorro in my tool box. did u scrape the old gasket off well and use gak? im just up in mundaring
  20. #20
    VN
    Mar 2009
    yeah mate add me, rpinkerton18@hotmail.com
    only way to get that snapped one off is to drill it out, nothing is sticking out
  21. #21
    Set of thongs
    Dec 2005
    Stonedville
    easy peasy
  1. vs clubby ready for dyno
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2009, 03:29 PM
  2. Need Help, I'm ready to burn it
    By freax in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2009, 12:17 AM
  3. lets get ready to rumble
    By samvlcal in forum The Pub
    Last Post: 24-09-2006, 09:39 PM
  4. Ford - Whoa! It's Ready
    By Bax in forum The Pub
    Last Post: 23-10-2004, 12:38 AM
