Results 1 to 17 of 17
Thread: My VS Acclaim problems. Need help!
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Default My VS Acclaim problems. Need help!
    Well, as the title says, I have a few problems.
    I only just recently bought the car off a mate of mine.
    It's done roughly 215,000k's.
    Im pretty sure it's got a rear main seal blown... 6 - 700 bucks to repair...
    Got the car for 2 without rego...
    Problem 1 - When the headlights are one, sometimes the brakes in the tail lights wont go on. It happens every 1 in 6 - 7 times.. Just wanting to know what can fix it...
    Problem 2 - It's really slow in changing gears, disappeared when I cleaned the throttle body but came back a week later...
    Could it be the really old filter it has in it?
    Problem 3 - One of the rear tires is wearing on an angle. The outside is fine, plenty of tread but the inside is almost down to the wear marks...
    There's not much more I need help with...
    Thanks for any information given guys!
    VT spac super6
    Nov 2008
    Riverton sa
    Are you pointing out it has a rear main seal as something special...?
    all engines run a rear main seal..
    now to the questions
    its possible the light problem is just a dodgey earth try cleaning all contacts at the lights
    try getting the trans serviced it probably hasnt been done in years
    and youll need to get a wheel alignment generally about 50 bucks
    whitey152's Avatar
    whitey152 is offline cruzen
    1996 vs berlina
    Jul 2008
    port macquarie
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Re the rear main seal - you can pull the trans yourself and then it only costs about $30 for the seal. While you are under there drop the pan on the trans and change oil/filter/gasket for another $60. Otherwise you will be paying big money to mechanics for repairs. You can get plenty of help on this forum.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Well, the problem doing it myself is that I dont have the tools to do so.
    I can just do small stuff really.
    She also needs new engine mounts so I can do that at the same time.
    I could always ask my gf's uncle to help maybe?
    I know the rear main is a days job... That 3 gaskets are done at the same time..
    The transmission problem is weird though, cause it got smoother when the throttle body was cleaned?
    This girl needs a good lot of loving..
    VP Exec
    Jun 2005
    Quote Originally Posted by Wombles View Post
    Possibly throttle position sensor?
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    VZ SV6
    Oct 2008
    Newcastle NSW
    You probably need a camber kit on the rear, only the front end is adjustable (ie. when doing a wheel alignment) without it
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Ah crap...
    Is it normal for a Commodore, when starting up, to go to 1500 revs then slowly goes down under 1000 in idle?
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    Mine does it, but it's done 350 000km.
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by sly_gen3 View Post
    so i guess a turbo locks both back wheels together? or is that a supercharger? thats what my cousin told me. Who also happens too be my girlfriend. She has 2 heads aswell.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    VS Acclaim S1
    Nov 2008
    Mines only done 215000... Hmm...
    Yeah my mates does it as well, and his is around the same as yours. It hasn't done it since I've put a new starter motor in, old one died. I don't think it's anything too serious, it doesn't do any damage if thats what your worried about..
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Ok, well, found out the brake light problem.
    It was the switch on the brake pedal..
    Getting that replaced so it's all goods.
  15. #15
    VS Commodore series II
    Mar 2009
    Port Macquarie
    i think lukes right camber sounds right on the rear wheel is its acclaim i think its got irs
  16. #16
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Ah crap...
    Both my VR (260K) and my VS (380K) do this. they seem to hold the higher revs longer when running on 91 (I normally run both on 95). Im not sure why they do thyis, but i doubt its serious.
  17. #17
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    91 meaning petrol yes?
    I usually run mine on 98.
  1. VY Acclaim Problems
    By AdamAnt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-04-2008, 06:01 PM
  2. Problems with VR Acclaim
    By boness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2006, 10:40 PM
  3. VS Acclaim 1995 problems
    By paulandloz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2006, 03:14 PM
  4. VT Acclaim aircon problems ??
    By pmcollins in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2005, 09:13 PM
  5. vs acclaim problems
    By Ragg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2004, 02:38 PM
