Results 1 to 13 of 13
Thread: Air con not coming out of top vents????
    vs berlina II
    Oct 2009
    Default Air con not coming out of top vents????
    i have climate control system and being trying to figure ouit why it wont come out of the top vents just only coming out of feet vents possible cause to why its doing it?????
    helppp?????
    svle s/w limit run 80 20 got group a engine box
    Jul 2009
    Default demister and front vents
    Quote Originally Posted by jake01j View Post
    helppp?????
    $$$$$$$$$$$ dash neds to come out hage headache sold a car due to this tryed pulling as much of dash awy srarting with stereo suround then puling as much of the dash peices i could to get to the unit got to it but basicly undid the clip holding the plastic cover shut which was th cause off no air coming from the top vents quick solution but what eva other setting i sellected they remained on but you can close the vents on the dash quick solution but it worked i just removed the plastic panel that was closed full tim and that made it open full time but at least you can turn the vent off at the vent but as for your demister mate that you need the dash fully removed to fix the problem as this is also a roadworthy requirement your probally better off spending the money don know if its a hsv or not but there is a wreckers on heaterdale rd that are selling a vr and a vs for 1500 a peice but cash talks probaly get the vr or vs for 800 to a grand nice clean cars to maybe better option cos that dash removal is a huge job and costl
    MX83
    Jul 2008
    hills area, sydney
    Or, you would try and press the MODE button.Pretty sure there is 3 settings, being feet only, top vents only, or both.
    JCCC NSW
    Quote Originally Posted by Troy711 View Post
    My mum dropped me off at work one day and she was doing 90 in a 60 zone. When I pointed this out to her she said 'shut up, if you don't like my driving you can get out and walk'.
    Jul 2009
    Default ps
    helppp?????
    remove glove box the aircon and heating fan is behind ther check that out also
    push the plastic flap down with your hand see where your air blows from set it to high evan open it see what that does trial and error mate see how you go but it is costly and as i said vr vs at pick pay n go have to of them no reg but are very clean streight cars and the price you would be paying to fix the air con and demister you would be better off buying one of them cos if your car isnt a hsv and vr n vs cars arnt realy worth much but if you had a clubby or senator then yeah fork out the dough to get a auto elec to fix it if not pick up one of those nice ones i mentioned everything works on both so you could use yours and another to build up a very nice vs
    Jul 2009
    just noticed mate its only a vr funny thing is the vs this place has is the same blue plus ecotec motor which personly i would prefure that engin over the vr as the vr has 127kw when the ecotec has 157kw plus whateva bolt on upgrades you have added will also bolt strate u and add the extra kws headers rampod all adds up to extra end rigure and for a few extra pennys than getting that headache fixed and a little extra work the way i would go about it any way
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    IF it's the climate control soloniod block that's the problem, it IS replacable without pulling out the entire dash, but its a prick of a job. Pull the headunit out and you should be able to get to it from there
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Benny, Why are you saying it's such a huge and costly job when you don't know exactly what the problem is.
    Jake, we need a bit more information. Does it only come out the foot vents no matter what button you press or is it just the face vents that don't work? With the models with climate control there are two main possibilities. 1) you may have knocked the tiny vacuum hose which attaches to the rear of the manifold. Vents need vacuum pressure to open and close. 2) the other option is a faulty vacuum solenoid which is located under the stereo. Worst case scenario is you'll need to remove the glove box, the fuse cover under the steering wheel and the stereo surround and plug in a new or second hand solenoid.
    I have had problem #2 for two years now and I can usually get the face vents working by bashing the side of the stereo surround where my left knee is.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    Philthy's Avatar
    Aug 2005
    Lol, don't get ahead of yourself there benny, its a $10 job. Not worth selling the car over
    EDIT: #2 as scooter just described is what I'm talking about. If it has only just developed this problem, sometimes going over bumps might make the top vents work again. Thats a pretty good hint that its the vaccum solenoids
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Also check all your vac lines under the bonnet. Cheap fix. If one pops off then it wont work properly.
    and 3 Dangerous non ABS VN's
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Quote Originally Posted by Philthy View Post
    Replaced my soloniod all good.
    Here is a pic of it see it has round holes at the bottom of the pic.
    This is what u need to replace. They are not cheap $120 for me but I work for a dealer.
    Attached Thumbnails Attached Thumbnails Air con not coming out of top vents????-dsc01422.jpg
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Philthy's Avatar
    Aug 2005
    I bought mine of someone on here out of a wreck for about $10-30, so I figure even if it goes after a year I can replace it at least 4 times before it would have been cheaper to buy a new one
    VS_Pete_1's Avatar
    Dec 2007
    Yes you are right that is cheaper than a new part.
    VS_Pete_1's Avatar
    Dec 2007
    By the way I didn`t tell him to buy a new one he is a big boy and I am sure he can make his own mind up what he would like to do.
  1. Smoke coming out the air vents !!! HELP !!
    By nilprapai in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 11:54 AM
  2. steam coming though the vents
    By MR__CALAIS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2009, 07:35 PM
  3. no air coming out of vents
    By lilmoz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2006, 11:16 AM
  4. Smoke Coming Out Of Air Condition Vents
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2005, 07:24 PM
  5. Water coming out of floor vents
    By Phiness1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2004, 08:57 PM
