Results 1 to 6 of 6
Thread: autowatch alarm issue
    vs clubsport
    Aug 2008
    Default autowatch alarm issue
    hey guys ive had this autowatch alarm installed in my vs clubby been like 1 n half years im having some dramas with it sumtimes when i press the imobiliser to lock the doors all four doors lock when i press the buttom again to open them only the drivers door knob opens and the others stay locked but if i fiddle with the passengers and rear door lock then press it again all four doors lock and open all sweet
    could this be caused by the alarm system playing up just drives me insanse
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    isnt this what later model commodores do? when I had a VY, if you held the unlock button down, it would unlock all 4, but if you only pressed it quickly it would just do the drivers door?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS Berlina 3.8
    Dec 2008
    Standard isn't it? You press it once to unlock, the drivers door pops, you press it a second time and the rest pop. My VS does it. I'd rather it, I rarely need the other 3 open.
    vs clubsport
    Aug 2008
    ah ok so im guessing it would be a waste on buying a alarm seems like its a common problem
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    It's not a problem it's a design feature to improve security. It doesn't allow someone to get into your car via the rear or front passenger doors after you have unlocked your car. For example, women sometimes open the driver's door and put their handbag on the front passenger seat. Only takes a few seconds and it's gone.
    vs clubsport
    Aug 2008
    ah i understand i just thought it was playing up
LinkBacks (?)
  1. Disabling Autowatch alarm system?
    By betts in forum General
    Last Post: 02-08-2009, 08:38 PM
  2. vz sv6 alarm
    By lenzo85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-06-2009, 10:22 PM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. What car alarm?
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2006, 10:35 PM
  5. VQ Statesman Alarm issue
    By VQStatey in forum Electrical Wiring / Questions
    Last Post: 09-03-2005, 09:57 PM
