Bro's Vs2 Stato V6, had tension pulley seize up on the hway, anyways now its got the oil light flashin, no errors jst this stupid light.
Can still see oil in the valley cover soo not sure if it is low pressure, any idea's.....
AYE!!
Did the belt get flung off? If so check the oil pressure switch and the wires going to it (check it even if it didn't come off)
nah htey still look all intack, had a fiddle with em n stuff
It starts say after 3min n it really flashes like 3 a sec'd
Its got oil to nice n full
Check with an oil pressure gauge to see if it is indeed low pressure.... but you probably would have noticed by now if it was (rattles etc)
they also get moisture buildup and falsely come on ... you could try just replacing the sender switch they're not too expensive anyway.
Other nite on closer inspection found the oil sensor n wiring was gone, got taken out by the fan belt comin off.
I fort the sensor was in vert posi like the buicks, but behind the pwr steer pulley.
Turns out it hangs out the front horizontally, got another one for me bro $25 all sweet.
Stupid Eco's, who would design it this way, so if the belt comes off it can smash it, buicks its hidin away. Much betters
